Long boot after battery removal - How to change Power Plans to "NO bat
pstein
2:04 AM
Until recently I had in my notebook a battery.
I removed it due to defects and don't want to buy a new one.
Unfortunately the boot process slows down dramatically.
It now takes approx. 5-10 minutes until Windows 7 shows the Login screen.
I guess its because the hardware related detection parts search for the non-existing battery.
How do I tell Windows 7 "There is no battery any more"?
I guess it has something to do with Power Plan settings.
Peter
win7pro 64bit
win7pro 64bit
Don't see any relation on slow boot and no battery, must be something else.
- Did it shut-ed down while running?
- Schedule a check disk. On a CMD window type chkdsk c: /f
- Do a system file check. On a CMD window type sfc /scannow
- Check your power plan on the advanced options.
    custom build
    Windows 7 HP 64
    i5 6600K - 800MHz to 4200MHz
    GA-Z170-HD3P
    4+4G GSkill DDR4 3000
    IG - Intel 530
    Samsung 226BW
    Thermaltake 450W TR2 gold
    500Mb/s
    Firefox 64
    TinyWall firewall
    Asus Q550LF
    Windows 7 Pro
    i7-4500U 800MHz to 3.0GHz
    Asus Q550LF
    (4+4)G DDR3 1600
    Realtek
    LG Display LP156WF4-SPH1
    1T HDD for data
    500 Mb/s
    TinyWall firewall
