Solved Loud sound thump on power up and down
ICIT2LOL
Confusion Therapist
3:55 PM
Central West NSW
I have just got my Ivy Bridge up and running again but am faced with another small problem and that is I get the loudest thump / whack through the sound system on power up and down.
Now it doesn't matter whether I have the sound turned down to zero the sound is still there especially on power down. I havn't tried unplugging the sound system but am assuming it is only coming through it anyway.
Sound is through an Asus Xonar DG card and I am not wanting this thumping to go on much longer in case it produces surges that might damage the rest of the board set ups.
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
You are not having much luck lately are you John :cry:
How about trying with the speakers/sound system connected to the onboard sound instead of the Xonar. If the problem goes away then you know it's some kind of issue with the Xonar.
Paul.
Windows 7 Professional 64 bit
Paul.
Ok Paul I whip out the Xonar and try that maybe the Xonar has eaten the biscuit and I will have to replace it. :)
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Well have found a solution if it is a solution that is to have the Logitec turned down to 25% or less and use the volume control on the Xonar / keyboard at least it is not trying to turn the speakers inside out.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
