mouse problem with loud noise
ollingfort
3:41 PM
Hi
I hope you can help me.
Got a new computer a couple of months ago with HID-compliant mouse supplied (optical - sensor plugs in the back). Loaded in Windows 7 and for a couple of months everything was fine.
Then yesterday, I was listening/watching a video when a continuous loud pitch noise started. Turned off speakers and computer. Started up computer and all was well again for about 30 mins, then the noise again and the mouse froze. Now again today after about half an hour, same noise again, and the mouse won't work unless I switch computer off and start again, and so on.
Does anyone know what could be going on here? The mouse is a Microsoft Ver. 6.1.7600.16385 (win7-rtm.090713-1255).
Thanks.
Advent QC-8003 desktop PC
windows 7 Home Premium
Intel Core 2 Quad Q8200 processor (2.33GHZ)
Intel DG451D
8GB DDR2
512MB NVIDIA GeForce 9600GT
IDT 92HD73EHD Audio Codec
VGA - generic non-PnP
1000 GB Sata II
Blu-Ray player and DVD Rewriter
92.33ghZ, 1333MHz FSB, 4MB Cache)
Where is the high pitched noise coming from? The speakers, or from inside the computer?
I suspect the frozen mouse is a symptom, not the cause of your problem. Tell us more about your computer? Are you watching temperatures? Have the internals ever been cleaned of heat trapping dust?
Start rounding up your warranty paperwork.
BrightWorks Systems B4
Windows 7 Profession 64-bit
Intel Core i7-860 Quad
Gigabyte P55-UD4P
Mushkin 4x2Gb PC12800
Gigabyte GTX260 896Mb
Integrated 7.1 HD Dolby
2 Samsung 2220wm-HAS 22"
1680 x 1050 | 1680 x 1050
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless Comfort 5000
MS Wireless 5000
Cable and pretty darn fast
Hi Digerati
The noise is coming from inside the computer. Also, when switching computer back on I get a blue screen with white type (MS-DOS) telling me it's dumping memory and to run CHKDSK /F. Can someone tell me how do operate RUN on Windows 7?
I check to see if I can find exactly where the noise in the computer is.
Thanks.
Intel DG451D
8GB DDR2
1000 GB Sata II
There is no "Run" in Win7. You simply enter the command you want in the Search Programs and Files text box.
But if asking how to run chkdsk, you can do that in several ways. The easiest is usually by double-clicking Computer, then right-click on your drive, select Properties > Tools > Error Checking > Check Now. I usually have both boxes checked - you should at least have the first. You will likely be prompted to allow chkdsk to run at the next boot, you need to allow that. Note that chkdsk on large disks can take many hours to several days to complete, often appearing as totally locked up - the process should not be interuppted.
Gigabyte P55-UD4P
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless 5000
Thank you Digerati, I will scan tomorrow.
Cheers.
Intel DG451D
8GB DDR2
1000 GB Sata II
Keep us posted.
Gigabyte P55-UD4P
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless 5000
There's a "run" option in Windows 7, but it's not turned on by default.
Go to the Taskbar and Start Menu Properties, Start Menu tab, Customize button. There's a checkbox for the Run command.
The Search Programs and Files box is probably more convenient, though.
homegrown
Windows 7 Pro X64 SP1
Intel Core I7-3930k
Asus P9X79 Pro
16 GB Gskill DDR3-2133
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
I have gotten so used to the new method, I forgot the option to display Run could be enabled. Thanks.
Gigabyte P55-UD4P
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless 5000
Hi guys
Well I did a system scan as suggested. I don't think there was anything amiss. So I updated my Malwarebyte detector and ran a full system scan. It found 2 trojans.
I have since played Youtube and managed to watch a whole video without any problems.
So, could a virus (trojan) affected the computer the way it did? Could the trojan have affected the media aspect of the computer?
Many thanks.
Intel DG451D
8GB DDR2
1000 GB Sata II
Malware can do all sorts of things - depending on what its target is. The fact you found malware means there was a failure in your defenses. You need make sure you keep your system updated, patched, scanned and blocked as necessary and on a timely basis. You also need to make sure all users of that machine practice safe computing, and avoid sites bad guys wallow in, such as illegal porn, gambling, and especially P2P sites that tolerate illegal filesharing of copyrighted materials such as songs, videos, and other published materials.
You might want to re-evaluate you security programs to make sure they are adequate. I would scan again, and regularly with Malwarebytes's Anti-Malware (MBAM).
Gigabyte P55-UD4P
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless 5000
