My pc has better parts than my girlfriends but hers is way faster why.
bigboi972
9:44 PM
I have had my pc for about 3 years. My pc specs are listed on the pc specs section of my profile. My girlfriend has had her computer for six months her specifications are listed below. Her computer is way way way faster and launches programs way faster and is just way faster but I think based on my knowledge of computers I feel that I have better parts. Why does her computer run better than my pc. Knowing this will help me make a better decision when purchasing my next pc
her specifications
Operating system windows8
Processor: intel i5-3337u cpu @1.80ghz
installed memory 8.00Gb
Gpu indel hd graphics 4000
Microsoft Windows 7 Professional 64-bitIntel Xeon E3 @ 3.30GHzIntel(R) Xeon(R) CPU E...16.00GB Single-Channel DDR3 @ 666MHz (9-9-9-24)ATI Radeon HD 7950
Intel Xeon E3 @ 3.30GHzIntel(R) Xeon(R) CPU E3-1230 v3 @ 3.3
MSI Z97 GAMING 5 (MS-7917)
ATI Radeon HD 7950
(1) AMD High Definition Audio Device (2) USB Audio Device
(1) Samsung SSD 840 EVO 120GB ATA Device
(2) TOSHIBA MK7559GSM ATA Device
TRENDnet Wireless AC1200 Dual Band USB 3.0 Adapter, TEW-805UB
Well because:
1. She has a higher clock speed on her CPU.
2. She has a new 3rd gen cpu so it has newer tech.
3. She has 8gbs of RAM but you have less.
Windows 7 Professional 32-bit/Windows 8 64-bi...Intel Core 2 Quad Q6600/Intel Core i7 4790/In...2GB/16GB/4GBIntel G33/G31 Express(Vostro)/NVIDIA GeForce ...
Dell Vostro 400/Dell XPS 8700(Slightly Customized for me by Dell)/Toshiba Satellite T135
Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
Intel Core 2 Quad Q6600/Intel Core i7 4790/Intel Pentium
2GB/16GB/4GB
Intel G33/G31 Express(Vostro)/NVIDIA GeForce GTX 745(XPS)
HP 2009m(Vostro)/ViewSonic VX2250wm-LED(XPS)
1600x900(Vostro)/1920x1080(XPS)
Seagate ST3160815AS(Vostro)/Western Digital Blue(Satellite)
External:
Western Digital My Passport 0748
Samsung HM121HC
Dell L100)(Vostro)/Dell KB2133p(XPS)
Dell M-UAV-DEL8(XPS)
100 Mbit/s(Only when IPTV is plugged out)
Avast, Malwarebytes PRO
Internet Explorer 11
Note: Names with slashes between two different parts mean that the left is my old desktop and the right is my old laptop and the middle is my new desktop.(Unless specified)
Ping is horrible for servers overseas in US and Europe.
New laptop:LG Gram(Not available in US) Processor:Intel Core i3 4th Gen Ultra Low Power RAM:4GB Hard Drive:SK Hynix OEM MSATA or M.2 Graphics:Intel HD
4. She may have a SSD.
5. Windows 8 is faster than Windows 7 for some scenarios.
2GB/16GB/4GB
External:
Samsung HM121HC
What makes you think your gear is better. Her CPU has faster single core performance (most programs make no use of all the i7 cores and hyperthreads), her graphics chip is faster and her disk is probably faster too. In addition she has Win8 which is a bit faster than Win7 and a newer installation which is not yet all clogged up.
If you want more performance I recommend a SSD and a reinstall.
http://www.sevenforums.com/tutorials/219487-clean-reinstall-factory-oem-windows-7-a.html
Newegg.com - 250gb ssd
:ditto:
2GB/16GB/4GB
External:
Samsung HM121HC
cool guys thanks for the input is it possible to easily change the hard drive of a laptop.
ATI Radeon HD 7950
I also have another questions I clean my pc regularly put it constantly gets hot is their anyway to diagnose or help with my heating issue.
ATI Radeon HD 7950
You could get a cooling pad for your laptop.
2GB/16GB/4GB
External:
Samsung HM121HC
Cooling pad doesn't do the job and it make usage of laptop difficult.
Windows 8.1 - 64 BitIntel Core i5-4670K (Haswell)8GB DDR3-RAM PC1600 CL9 ADATA XPG V1.0 blackGigabyte NVIDIA GTX 770 Graphics Card (2GB, D...
Gigabyte GA-Z87X-D3H
Gigabyte NVIDIA GTX 770 Graphics Card (2GB, DDR5, PCI-E)
ASUS Xonar DX 7.1 | Turtle Beach HPA 2
Samsung SyncMaster P2270HD
1080p
Samsung 840 Evo 250 GB (OS only)
Seagate Barracuda 1TB S-ATA
Seagate Barracuda 250GB S-ATA
Maxtor 250GB S-ATA (Backup only)
WD Elements 500Gb/Go
750 watts
Zalman GS-1000 Special Edition
Zalman CNPS10X Performa
Logitech K350
Logitech M705 | Razer Vespula Mouse Pad
Virgin Media - 60Mbps
120mm fans x 4
(2 on top, 1 at rear, 1 at bottom)
when I had that heating problem, I used a blower at the slowest fan speed and cleaned the system just by pointing it to blower. You'll see a lot of dust blowsout from those fan vents and other compartments. Heat problem got reduced drastically. IDK whether it's the same thing that's clooging yours, try it.
Windows 7 Professional 32bitP6200 @ 2.13GHz2043 MBIntel HD graphics
Acer 5733Z
P6200 @ 2.13GHz
2043 MB
Intel HD graphics
C: Total - 49899 MB; D: Total - 149999; E: Total - 149999 MB; F: Total - 123107 MB;
Microsoft Security Essentials, ESET NOD 32
Mozilla
Dust buildup in lap tops is very common, when it gets bad you have to open the machine and physical clean it. Your fan is 3 years old, I would replace it while inside. You could install a new SSD while doing the fan. Then a clean install of W7 and you'll be much faster.
Win8/8.1,Win7-U64, Vista U64, uncounted Linux...AMD and Intell, 9590, 8350, i5 3570kCorsair G SkillCrossfired Sapphire HD 7950 Vapor-X, ASUS R9 ...
Custom, Dell and Lenono LT's
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
CFVFZ, GA990FXA, Z77e-itx
Corsair G Skill
Crossfired Sapphire HD 7950 Vapor-X, ASUS R9 280X TOP
Realtek ALC889
ViewSonic VX2770SMH 27" / ViewSonic VX2433 LCD 24"
1080i HD
Samsung SSD 840 Pro
OCZ Agility 3's
OCZ Vector's
WD's Blue, red, green, Velociraptors
Seagate USB3 & Hybrid's
ASUS Blu-Ray
ASUS DVD
Corsair AX1200i, Seasonice 850 Gold
Cooler Master HAF 922 & HAF 932, Lian Li Train case.
Air, Glacer 240L expanded, custom EK loop with duel D5's
Microsoft SideWinder X4 USB Keyboard / Logitech 250 PS2
Logitech G500 / MS wireless 5000
Best of 5ms / 75+ dn / 12+ up More or less.
MS esentials-MalwareBytes
Firefox Chromebook
I used to get cooling errors because of build up so i used a dust blower at the fan and after that, i got no more errors.
2GB/16GB/4GB
External:
Samsung HM121HC
Another aspect of her speed advantage could be her wireless speed. Some lappys have really poor WiFi performance. Look to find a ssd with 256gb of capacity or larger if needed and affordable. Then I used my stock spinner in an external usb powered enclosure, but then I use 64gb SD card in mine for data back up and more portable performance. Don't discount the ssd as it will also enhance battery run time as well as noise, vibration and heat!
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
I would reccomend a Samsung 840 EVO if getting a SSD.
2GB/16GB/4GB
External:
Samsung HM121HC
Not completely correct, It depends on who make it and the overall quality, you will get some really cheap ones, and some quite expensive ones, I have tried one before and i didn't notice too much of a difference, maybe 5-8 degrees but that 5-8 degrees can be a lot if the temps are really high, also the one i used wasn't cheap but it was expensive either, somewhat mid range, it was easy to use and done the job i needed it to.
Windows 7 Home Premium 64BitAMD A6-3420M 1.5GHZ OC - 2.0GHZ4GB DDR3 1600MHZAMD RADEON 6520G+AMD RADEON HD7470M 1GB DDR3
Packard Bell
4GB DDR3 1600MHZ
1366x768
500GB SATA
18Mb Unlimited
AVAST!
MOZILLA FIREFOX
I will most definitely consider replacing my fan and getting an ssd im just really worried about opening it and breaking it
ATI Radeon HD 7950
To replace the disk, you only have to open the disk bay. That's easy. The fan is another story. You have to watch the wires that go to the screen. Note that a SSD produces a lot less heat than a spinning disk - in fact it produces no heat at all.
Windows 7 Ultimate Retail Box (64-bit install...AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was requ...8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo n...Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Fro...
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
