Recently I had some computer issues and had to take apart my PC and refit it back. Everything is fine now but I just realised that my Nvidia GPU is being used as the HD audio device. Audio plugs are all in the motherboard jacks and not in the gpu, my gpu dosent have any audio jacks anyway.
I didnt even realise the issue until recently when I tried to record some gameplay footage and found my recording to have screwy audio. Everything else seems to be fine as far as sound is concerned. I need to know how I can go back removing my GPU as the audio device and re-enabling Realtek. Right now I have no realtek device manager in my control panel or my programs list.
I wasnt sure if it was as simple as re-installing the drivers and rebooting the PC and I've had some major issues with drivers in the past so Im wary of trying to fix the problem on my own.
My motherboard is: Biostar TP67xe
GPU is: Nvidia gtx 570
running on win 7 home 64bit
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Two things that I see. First, the NVIDIA Virtual Audio Device is probably what is taking over your sound. Disable it in the Device Manager and then restart the PC and see if the sound works again. You may have to manually set the "Speakers" (PC sound device) as the default Audio Playback device - in the Control Panel/Hardware and Sound and finally the Sound Panel Playback section.
The second thing I see is "High Definition Audio Device". This indicates the generic, basic function, Windows installed sound driver. This will work, but the correct sound driver, Realtek in your case should be installed. Download from Biostar for your specific motherboard model and install that. TP67XE :: Motherboard :: BIOSTAR
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Alright but before I proceed, I have 2 devices in my sound control panel.
I am not using any speakers and have headphones plugged directly to my pc. Should I disable the "speakers" and use "headphones" as my default device instead in my situation?
