need help for setting a network using dlink 5 port switch.
gparmar83
7:38 PM
hi guys,
i need help trying to make a network with 2 PCs using a dlink 5 port switch.
one of the PC is having a WiFi card as well. i want to create a wired network between PCs and using a straight through cable. even though i disable the WiFi card and assign the static IPs to both system but not able to ping between them. and i want to share internet on other PC through first PC WiFi card.
and both the PCs are on same work group.
am i missing something or doing wrong something and drivers for the cards are installed on both the pc.
any help appreciated.
win 7 professional 64x
Are you using a router anywhere? If so why not just use dhcp.
Provide ipconfig /all command outputs.
Open start menu
In seach type cmd, press enter
In command prompt type ipconfig /all
Do that on each pc.
Back to the old ICS problems again LOL. Get a router for the love of God!
Modem>Router>Switch>Machines=easy
Not Modem>Wireless>Machine>Ethernet>Switch>Other Machines= difficult
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Crazy how much easier everything is if you spend $50.
