Need Help Identifying problem Bluescreen Error Messages
PopeyeMills
9:09 PM
Bedfordshire, England
I've had my new computer since end of October and bar two days have experienced the 'Bluescreen' error messages at least once a day after a computer crash and re-start. I have made no hardware changes since it was built and tested by Shuttle and the OS was installed by the dealer.
I'm running Windows 7 64-bit and have added very little software since it arrived. A summary of my computers hardware is below with the detailed system information in the file 'SystemInformation.zip' if that helps. I also attach a copy of my Minidump folder in the file 'Minidump.zip'.
Can anyone help ??
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7600 Build 7600
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name ALAN-PC
System Manufacturer Shuttle Inc.
System Model SX58
System Type x64-based PC
Processor Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz, 3068 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 080016, 21/05/2009
SMBIOS Version 2.5
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United Kingdom
Hardware Abstraction Layer Version = "6.1.7600.16385"
User Name Alan-PC\Alan
Time Zone GMT Standard Time
Installed Physical Memory (RAM) 6.00 GB
Total Physical Memory 5.99 GB
Available Physical Memory 4.47 GB
Total Virtual Memory 12.0 GB
Available Virtual Memory 10.2 GB
Page File Space 5.99 GB
Page File C:\pagefile.sys
Shuttle SX58
Intel i7 950
Corsair 6Gb kit 3x2Gb DDR3 1333
Sapphire Radeon HD 4850 512Mb
Realtek Audio Motherboard
HP LP2475W
2 x Seagate 500 Gb SATA 16 Mb Cache
Can anyone help ??
System Name ALAN-PC
System Model SX58
SMBIOS Version 2.5
I took a quick look at 2 of your dumps both were identical. The dugcheck 124, the hal.dll file, and the memory corruption is indicative of a hardware problem.
I would first download and run memtestx86 overnight.
Run a system file check by typing cmd in search>right click and run as admin>then type SFC /scannow
let us know the results
I would also
If overclocking stop
if you are running a raid upgrade the driver.
Upgrade bios, and video.
There are several drivers that are from 2006-2008
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\K\Desktop\110909-16255-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*d:\symbols*Symbol information
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02e01000 PsLoadedModuleList = 0xfffff800`0303ee50
Debug session time: Mon Nov 9 13:19:17.485 2009 (GMT-5)
System Uptime: 0 days 0:25:33.485
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {4, fffffa80062a88d8, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
6: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000004, PCI Express Error
Arg2: fffffa80062a88d8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
BUGCHECK_STR: 0x124_4
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 6
STACK_TEXT:
fffff880`0313da78 fffff800`033f0903 : 00000000`00000124 00000000`00000004 fffffa80`062a88d8 00000000`00000000 : nt!KeBugCheckEx
fffff880`0313da80 fffff800`02f87513 : 00000000`00000001 fffffa80`054c20c0 00000000`00000000 fffffa80`054c1b70 : hal!HalBugCheckSystem+0x1e3
fffff880`0313dac0 fffff880`00f5daff : fffffa80`00000750 fffffa80`054c20c0 00000000`00000000 fffffa80`062a8010 : nt!WheaReportHwError+0x263
fffff880`0313db20 fffff880`00f5d526 : 00000000`00000000 fffff880`0313dc70 fffffa80`06338d80 fffff880`0313dbf0 : pci!ExpressRootPortAerInterruptRoutine+0x27f
fffff880`0313db80 fffff800`02e6ecfc : fffff880`03115180 fffff880`0313dc70 fffffa80`06338d80 00000000`00000001 : pci!ExpressRootPortInterruptRoutine+0x36
fffff880`0313dbf0 fffff800`02e7b6d2 : fffff880`03115180 fffff880`00000001 00000000`00000001 fffff800`00000000 : nt!KiInterruptDispatch+0x16c
fffff880`0313dd80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x32
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_4_PCIEXPRESS
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
OK Thanks. Will run Memtest86 overnight as you suggest. Although it already passed the Windows 7 memory test.
1. Result of SFC scan - Windows Resource Protection found no integrity violations.
2. Checked all the device drivers in Device Manager and they all seem to be up to date.
3. Not running in RAID configuration - just 2 identical Seagate 500 Gb's.
4. Not overclocking anything to my knowledge. Certainly haven't changed anything since built by ICubes.
5. Computer bought in October - BIOS last updated by Shuttle in May 2009. But I will check it.
6. Video is up to date.
Thank you for your thoughts, will update tomorrow after the Memtest.
Don't know what a dugcheck 124 is, or the importance of the hal.dll file which seems to be from Microsoft. Is this significant?
Shuttle SX58
Intel i7 950
HP LP2475W
Popeye, see if your video card is seated well in the slot. Take it out and put back in again. If you can run it without the card for a while and see if the problem persists.
Are your video drvers up to date?
Wally, Innc.
Windows 7 x64 finally!
AMD Athlon II X2 240
Biostar TA790GX XE
OCZ Platinum 4GB DDR2 1066 (will not work past 800MHz)
MSI R4670-MD1G Radeon HD 4670 1GB 128-bit GDDR3
ATI High Definition Audio Device Realtek ALC888
HP w19e
Western Digital Caviar Green WD5000AADS 500GB SATA
Western Digital Caviar Blue WD5000AAKS 500GB SATA
Athena Power Micro ATX 400W
HEC 6T 6T10BB Black MicroATX Mini Tower
stock
wired, many keys
HP wireless, 2 buttons, 1 wheel
DSL 2Mb (recently getting 1.65M!)
PopeyeMills,
from my experience I can tell that your memory may pass the win 7 memory test even if it is faulty. when I tested my defective 2 GB DIMM together with another 2GB DIMM that works fine, even MemTest86 ran for over 12 hours without a single error. so if I may give you an advice, I would suggest to test your RAM modules one at a time - that way you will get the most reliable results.
check out this thread for the full chronology of my odyssey.
good luck,
~sahib
custom build
Win7 x64
AMD Phenom II X4 955 3200 MHz
Gigabyte GA-MA790XT-UD4P
4x2048 MB Kit G.Skill Ripjaws 1333 MHz CL7
Sapphire Radeon HD4890 VaporX 1 GB GDDR5
[onBoard] Realtek ALC889A
Dell 2407WFP 24"
1920x1200
0.25 TB Samsung (SSD840)
2.00 TB WD Caviar Green (WD20EZRX-00DC0B0)
1.00 TB WD Caviar Black (WD1001FALS-00J7B1)
0.50 TB Samsung (HD501LJ)
BeQuiet! BQT E5-550W
Zalman 9700 LED
not overclocked
Thanks to zigzag3143, wallyincc and sahib for their suggestions.
The situation at present is that neither Windows 7 memory test or an overnight run of Memtest86 revealed any errors (despite 9 passes).
The motherboard BIOS is the most current available.
The video driver is the up to date although its a Microsoft approved one. Will check ATI's site for something more recent.
Haven't had a crash since yesterday, which is a relief, and from the forums it would seem I am not alone in the world, although that's hardly comforting.
Will try Wallyincc's suggestion first as that is probably the easiest to try.
I have read elsewhere on this site that there is some Memtest can find errors on memory chips when they are tested one at a time, so will try sahib's suggestion if re-seating the graphics card doesn't bring any improvement.
Thanks again.
Shuttle SX58
Intel i7 950
HP LP2475W
Me and My Big Mouth
No sooner had I posted a reply on a day without a Bluescreen crash, and guess what. 5 minutes later and I'm struck again, just as I was downloading what seems to be a more recent graphic driver from Sapphire.
If anyone would care to look I have attached the MiniDump file.
No error message on re-start, just the message 'Windows has recovered from an unexpected shutdown'. And that has been on the screen for the last 10 minutes.
Shuttle SX58
Intel i7 950
HP LP2475W
The minidump file.......
Shuttle SX58
Intel i7 950
HP LP2475W
Reboot into safe mode + networking.
Download the latest driver for the card from ATI's site. Extract it to C:\ATI. Close installer after it extracts.
In device manager, right click on the card. Update driver software. Browse my computer. Let me pick. Have disk. Browse. Double click on the first .inf when viewed in alphabetical order, somewhere inside C:\ATI
Hit ok, maybe next after...let it install. When done, reboot to Windows normal mode and hopefully enjoy the new driver.
self built
7600.20510 x86
P4 550 3.4 GHz HT running at 3.5 GHz
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
OCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHz
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
Latest Update.
Windows 7 crashed again. This time did not restart and didn't get an error message after switch off and on.
MiniDump file attached if anyone can help.
I have tried reseating the graphics card.
I have installed the latest graphic driver from ATI under safe mode with networking.
I have tested the memory chips seperately, using Memtest, over the course of a day without error.
Nothing tried seems to help. I have noted that alot (but not all) of the crashes seem to occur about 10 mins after startup. What that could mean I don't know.
Anybody??
Shuttle SX58
Intel i7 950
HP LP2475W
See this link about 0x124 errors and what you can do to try to alleviate them. (No overclocking, at least to troubleshoot. Then you can do as you want, after. If you're overclocking, please only post further dumps or continue seeking help when not.)
You also have these ancient and older drivers on the system. Update them to 2009 versions or uninstall from system.
secdrv secdrv.SYS Wed Sep 13 09:18:38 2006
000 000.fcl Fri Sep 26 09:11:22 2008
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
