need help like mad going crazy
Sound Cards
ATI High Definition Audio Device
it just saying it cant detect it but it says its enabled and working but it keep saying its not pluged in does it matter if i have a pc audio input in the back of my tv ?
What says it cant detect what? Do you get this error on your PC, on your TV?
If you have other audio inputs into your TV then you need to choose which audio input it should use. It can not use two audio inputs at the same time. It can only use the input which is enabled. This needs to be enabled on your TV.
Regards....Mike Connor
Several, including Windows 7 x64 Ultimate
says it cant detect the ati hdmi audio out put and how do u make it choose which one it uses
windows 7 x64
Intel Core i3 370M @ 2.40GHz 32 °C Arrandale 32nm Technolog
Gateway SJM70-CP (CPU 1)
6 gb ddr3 memory
Sound Cards ATI High Definition Audio Device Realtek High
What device says it can not detect the ati hdmi audio output? On what screen are you seeing this error?
The TV screen, or your PC screen?
In order to make the TV accept a certain input, you need to use the TV menu.
