Solved Need help! searching for blower to clean PC
Working with a wrist strap is a real pain in the butt ! :mad:
Try putting it on your wrist instead of your butt. :doh:
Sorry, Brian. I couldn't resist. I'll give myself 40 lashes with a wrist strap. :roflmao:
Sony Vaio VPCEB47GM Laptop
Win 7 Pro 64-bit
Intel i5 2.4 Ghz
8GB DDR3
Intel HD 3000
IDT High Definition
15.6 WGXA Anti-Glare LED
1280x800
640Gb 7200rpm
I think the video I posted earlier is pretty good with the exception that a demonstration of the wrist strap should be given, or how to otherwise ground oneself.
I know of no one who says its OK to keep the PC plugged in. I always unplug, remove a laptop battery, and hold power button to release any residual power. These are standard precautions.
I also hold back from touching any electronics without holding the case. This has always been enough for me.
Holding the power button is new to me. You're talking about all PC's right, not just laptops? And for how long?
Sorry to be so pesty but have never been inside this one yet :o , only had it about a year. It's one of the newer,small towers (eMachine) & I'm quite curious. It looks so small compared to the old style.
Microsoft Windows 7 Home Premium 64-bit 7601 ...AMD Athlon(tm) II X2 220 Processor3.00 GBNVIDIA GeForce 6150SE nForce 430
emachines
eMachines EL1358G
3.00 GB
1280 x 1024 x 32 bits (4294967296 colors) @ 60 Hz
(1) WDC WD10 EADX-22TDHB0 SCSI Disk Device (2) Generic- Multi-Card USB Device
came with PC
came with PC
IE 9
don't know how to get info for the other 5 areas
Yeah I work in those pretty regularly and it just takes extra caution, do everything in super slow motion, don't take any shortcuts or assume a screw won't drop or a spark won't jump.
Especially the part about dropping screws. :o
Win 7 Ultimate 64 bit
Intel i7-3930K
ASUS P9X79 WS
Asus Xonar Essence STX
1920 x 1080, ?
Samsung 4TB 850 EVO SSDs (4)
Corsair HX750w
Logitech G510s
Logitech M525 (two in use)
=< 32Mbps down, 8Mbps up
IE11
I finally just got it done I think. Only one fan that I could see & it was quite clean. Can't believe I let myself get so twitterpated over it for nothing. :o
emachines
eMachines EL1358G
3.00 GB
came with PC
came with PC
IE 9
