Need help with diagnostic and fix
oceanik
12:39 AM
Hi all,
I've some weird things happening on my computer and I hope you can help me sort out things.
I've a fairly new computer with Windows 7 ultimate X64 and a WD1001 Caviar black hard drive.
I've had issues installing applications or drivers in the past (it was taking literally hours) but nothing really bad.
About 3 weeks ago my Windows update stopped working (it stays at 0%) and I couldn't update the virus definition in MS security essentials either.
I can't stop some services (like Win update) because of ""access denied" even though I do it as admin.
I tried to install a hard drive diagnostic tool: WD's Data Lifeguard diagnostic (I know it doesn't seem to be available for Win 7) but when I run it, it says I don't have any physical drive (but it sees the logical drives!)
Today I can't even start WinDLG!
I can run chkdsk but it returns nothing abnormal.
When I run with /R it says:
C:\Windows\system32>chkdsk /R
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another process.
I don't any other process is running though
I tried to install HD Tune Pro (for Win7) but I can't install it (it says "Unable to execute file in Temporary directory. Setup aborted. Error 5: Access is denied")
What's going on?
Do you think it is a hard drive issue? a Windows 7 issue? A RAM issue?
Thanks in advance for your help!
A
Let's start with these free diagnostics:
H/W Diagnostics:
Please start by running these bootable hardware diagnostics:
Memory Diagnostics (read the details at the link)
HD Diagnostic (read the details at the link)
Also, please run one of these free, independent online malware scans to ensure that your current protection hasn't been compromised: Malware (read the details at the link)
Home built (x64), Lenovo x61s Tablet, Samsung Netbook
Win7 x64 + x86
Intel i7 920, other Intel chips, and the Atom in the netbook
Asus P6T Deluxe
12 gB; 4 gB Lenovo; 1 gB Samsung netbook
ATI 4870
Yes, I have one of these
32" Sharp Aquos TV
800x600 - I have vision issues
4 - 150 gB Velociraptors in RAID 5
Promise controller
1000 watt (can't recall the brand)
Antec 300
Big honking cooler that was rated highly at Toms Hardware
Microsoft Natural
Logitech Trackman
Cable
GeekSquad UPS
CyberPower UPS
DLink DNS-323 NAS (2 tB)
Netgear wireless router as an access point
Netgear wired router FSV-318
Home network consists of
4 desktop computers (2 Vista, 2 Win7)
1 netbook (Win7)
4 laptop computers (XP, 2-Vista, Win7)
Wii and XBox 360
Thanks usasma.
Unfortunately I can't do what you recommend:
I've tried to do a memory test and downloaded MemTest but I can't unzip it (it just hangs for hours)
Same with Spybot that I tried to unzip without success.
As for online malware scan, I can't run them either (well, I ran eset that didn't return anything): Neither F-secure not Bitdefender were able to run.
But, it now makes me think (just a thought, nothing to prove it) that there is something wrong with Windows temp folder.
It says "setup cannot copy the file to oscan82.ocx
Ensure that the location specified below is correct or change it and insert unknown in the drive you specify"
Copy files from C:\Users\...\AppData\Local\Temp\IDC2.tmp
Sounds like a bad hard drive to me.
Me
Windows 7 32-bit
AMD Phenom Quad Core 9750 2.4GHz
ASUS M4A785-M
Corsair XMS2 4GB(2x2GB) DDR2
XFX ATi Radeon HD 4350 1GB DDR3
1024x768
Seagate Barracuda 750GB
Ultra 650W Power Supply
NZXT Tempest
6 Case Fans(2x140mm,3x120mm,1x80mm)
I run a chkdsk and it was fine (0 Kb in bad sectors)
I can't run a chkdsk /R though
I'm trying to burn the .iso WD diagnostic tool but Windows doesn't let me :(
Edit: I was able to burn it but when I boot nothing happened: it booted on my CDRW but then black screen
