Solved Need help with Epson printer ink level indicator not working.
GARoss
Power User
6:14 PM
Michigan - USA
I'm not sure is this is the correct place to post so please move it elsewhere if necessary.
I've had this issue for awhile but recently got burnt with a bad print because cyan was low on my Epson Artisan 710 printer. I've attached a capture of the properties window that shows printer ink level indicator not working.
So far, I've reinstalled Epson software & contacted Epson. Epson did respond & said this was caused by either my PC's firewall or virus protection. I have tried disabling both Microsoft Essentials & Windows Firewall temperately but still no change. I do use my LAN network to connect to the 710 but cannot find how to set Microsoft Essentials or the firewall to ignore the printer.
Any ideas?
Windows 7 64-bitIntel Core i5-2500K 3300 Mhz16Gb Patriot PC3-12800 1600 MhzEVGA GeForce GTX 560 Ti (Fermi)
Custom built 2011
Windows 7 64-bit
Gigabyte P67A-UD3-B3
On Motherboard
Dell U2412M & NEC EA232WMi
DELL 1920x1200 - NEC 1920x1080
Crucial 128 Gb SSD
Hitachi Deskstar 2Tb 7200 RPM 32MB Cache
Seagate Barracuda 500Gb 7200 RPM
Hitachi GST Deskstar 1.5TB 7200 RPM 64MB Cache
Seasonic M1211-620 Bronze
Antec Solo
Tuniq Tower 120 Extreme Rev 1
Apple
Microsoft
5mbs
Sunbeam PL-RS-3 Rheosmart 3 Fan Controller 3.5" Bay 3 Channel 30W Fan Controller Panel
when you reinstalled the epson printer software; did you completely uninstall it first then reinstall it or did you just try installing over it?
Windows 7 ultimate 64-bitIntel I7 2600K 3.4ghzCorsair 16gb ddr3 1600mhzNvidia Geforce gt 430
custom built
Asus Evo P8P67
Sound Blaster Titanium x-fi pci express
Dell E198WFP
1 western digital 2TB drive.
Antec 1200 watt
Inwin Dragon Rider
6 case supplied cooling fans
logitech mk700
logitech m705
25-50mbps download; 10mbps upload(i think)
avg free 2014
mozilla firefox
Also have a pretty bad speaker setup which is a klipsch promedia 5.1 surround speaker setup with huge subwoofer and lg blu ray player/writer. Also a hp officejet pro 8600 plus wireless all in one and a logitech s7500 webcam.
Have you tried the maint. features as many have a head clean feature and could help. Also remove all ink cartridges and wipe the contacts with a alcohol dipped q-tip and allow to dry then re-install ink.
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
The printer has an LCD screen & ink levels work correctly on the printer itself.
Custom built 2011
Windows 7 64-bit
On Motherboard
Crucial 128 Gb SSD
Antec Solo
Apple
Microsoft
5mbs
I don't recall. I'll try complete uninstall, reinstall. I do use my network, not USB, to connect to the printer. This is why Epson Support said it has something to do with firewall or virus protection. I should try USB & see if it works with that connection, too. I'm not seeing any block list with either of these & as I said, I did shut off but it didn't fix the issue.
Custom built 2011
Windows 7 64-bit
On Motherboard
Crucial 128 Gb SSD
Antec Solo
Apple
Microsoft
5mbs
Well, this is strange. I uninstalled everything Epson, then downloaded Epson 64-bit software for the Artisan 710 & installed. Everything is working now! The only thing I can think of is Windows sometimes drops connection with the 710 (maybe because it's LAN connected ???). Once found, Windows says it has the "proper" driver for it ready to install. Maybe this was the wrong driver or not the 64-bit version. In any case I'm glad it's working again.
Thanks for the help! :)
Custom built 2011
Windows 7 64-bit
On Motherboard
Crucial 128 Gb SSD
Antec Solo
Apple
Microsoft
5mbs
Glad that worked.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
So it sounds like the uninstalling and reinstalling of the printer software worked for you?
custom built
Asus Evo P8P67
Dell E198WFP
Antec 1200 watt
Inwin Dragon Rider
logitech mk700
logitech m705
avg free 2014
mozilla firefox
It sure did.
As I stated in my post, Windows - for whatever reason - occasionally drops connection with my printer. I don't know if it's because it's on a LAN connection or I don't print all that often - don't know, it just does. Anyway, when adding the printer Windows asks to install the recommended driver already installed or another driver. I have accepted the recommended driver each time assuming it's the previously installed Epson driver. Maybe that driver wasn't up to date?? In any case doing a complete uninstall / reinstall with drivers downloaded from Epson, as you suggested, took care of the issue. I gave you a Rep for you well deserved suggestion. Thanks again! :)
Custom built 2011
Windows 7 64-bit
On Motherboard
Crucial 128 Gb SSD
Antec Solo
Apple
Microsoft
5mbs
