Need help with fixing Control Panel issues after running ASO
MidNightRunz
10:08 PM
Hey folks, I joined this forum a while ago but forgot my ID :doh:
I created a new ID to post this question. Anyways, here goes:
Last month I picked up a brand new laptop (Acer Timeline X3820TG). I recently installed Advanced System Optimizer, and ran it for the first time today, specifically these two functions (System and Disk Cleaner / Registry Cleaner and Fixer).
After I ran those two and clicked 'OK' at the prompts, I opened up control panel because I had to uninstall something. The control panel itself opened up, and I could click on the major categories, but the sub categories wouldn't open or load up.
For example, from the control panel, I can click on "System and Security" without any problems, but when I click on a specific function, it won't load up, such as Windows Firewall or Computer Backup etc etc... (Sorry I run a Korean version of Win 7 so I'm not sure of the exact terminology, but hopefully you get the picture)
Can anyone tell me why this is happening or how I can fix it? I know it has something to do with the registry but I'm stuck without a Win 7 CD, even though I'm running a legit version of Win 7 (OS was pre-installed into the laptop)
Thanks much!
JC
Custom / Acer Timeline 3820TG
Win 7 Pro 64bit / Win 7 Home 64bit
Core2Duo [email protected] / Core i5-430M
Foxconn Mars / Acer
6GB / 4GB
Nvidia GTX260 / ATI HD 5650
factory / factory
23" Wide LCD / 13.3" HD LED LCD
500+250+160GB / 500GB
650Watt RMS / laptop
Phoong2 / laptop
Zalman 9500 LED / laptop
Thanks much!
JC
Most of us dont recommend System optimizers especially those that modify registry. They cause more problems thatn they could possibly cure.
Is there a slim chance that you have a backup from before the problem?????
Do you have a win 7 dvd to do a repair install?
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Ken
Hey Ken,
I agree with you, I am never going to use ASO again!! I was unable to even access the restore / backup part of the control panel, but I found a workaround, and restored my system to an earlier state, and it worked :)
Too bad my laptop doesn't have an ODD, and doesn't come with a win 7 DVD... I guess I'll have to shop around for an external one.
Anyways, thanks for the help
Jung
Foxconn Mars / Acer
6GB / 4GB
factory / factory
Phoong2 / laptop
I am glad you were able to restore to an earlier point. Good work. Thanks for letting us know. Now, don't even think of using a third party tune up utility. :D
Home built
Windows 7 Ultimate 32 bit
Intel(R) Pentium(R) 4 CPU 3.00GHz
ASUS P4P800-VM Motherboard Chipset: Intel 865G + ICH5
2.50 GB RAM
NVIDIA GeForce 7600 GS
SoundMax Integrated Digital Audio (Chip)
ViewSonic VX 1962 wm
1680 X 1050
Seagate Barracuda 7200.10 80 GB
ST380215A ATA Device 18.6 GB
Western Digital "My Book" external hard drive 750 GB
Fan based
Microsoft Comfort Curve Keyboard 2000 v10 USB
Logitec optic USB
3.01 Mb/s download 0.64 Mb/s upload
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
Any suggestions as to a good registry cleaner / or tune up utilities?
If you have everything working alright now, make a disc image using free Macrium Reflect Macrium Reflect FREE Edition - Information and download.
You could also make a Macruim Linux Rescue Disc ;)
Thank you!!
Foxconn Mars / Acer
6GB / 4GB
factory / factory
Phoong2 / laptop
No, we don't advise or suggest theses types of program applications. They usually do more harm than good.
INTEL/D975XBX2
1280 x 1024
Rocketfish 700 W
DSL
IE 11
ATI HDMI Audio
Thank you!!
I concur with Jacee. I strongly urge you not to use a registry cleaner unless you are well versed in the registry and know exactly what you are doing. If not, then you are far better off leaving it alone, and definitely not placing blind trust in a program to do the job for you.
Windows is a closed source system. Developers of registry cleaners do not have the core code of Win 7 and are not working on definitive information, but rather they are going on past knowledge and experience. Automatic cleaners will usually have to do some guesswork.
Modifying registry keys incorrectly can cause Windows instability, or make Windows unbootable. No registry cleaner is completely safe and the potential is ever present to cause more problems than they claim to fix.
Registry cleaners cannot distinguish between good and bad. If you run a registry cleaner, it will delete all those keys which are obsolete and sitting idle; but in reality, those keys may well be needed by some programs or windows at a later time.
Win 7 is much more efficient at managing the registry than previous Windows versions. If you are very knowledgeable of the registry, you can use Ccleaner to delete keys left over when uninstalling programs. However, these few keys will not make 1 millisecond's difference in performance. If you run Ccleaner or any other registry cleaner and do not know precisely what you are doing, you will have problems down the road. There are no gains to be had from using a registry cleaner and the risk is great.
Forget all the "wisdom" you learned about XP. Win 7 is not XP and does not manage the registry the same as XP.
Registry defragger programs are a myth, too. They might trim the registry size by 8-12MB; but, they will not improve operating system performance. In fact, your programs’ performance will decrease.
Are registry cleaners necessary?
Back up the registry
This applies to third party tuneup utilities, too. They not only are unnecessary, but as you discovered, they can and will actually degrade and harm your system. Windows 7 will take care of itself just fine. It does not need the the tweaking that XP did.
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
IMHO a bunch of registry entries that you don't need won't hurt and you will not see a slow down but one needed entree missing can shut you down. I would guess that there are thousands of entries in the registry. I surly don't know how one would find out for sure how many there are.
