Need help with wireless printer
TLMCDANIEL62
2:42 PM
I bought a new wireless Epson Workforce 545 printer. It has worked without flow for quite some time (nearly a year). Now all the suddenly it wont print.I have it as a shared printer. There are three other family members on the network and all three others print without any problem. Mine worked fine and now wont print. It goes through the motions and then times out. All it says is "printer error". Nothing has changed. I have not installed anything new or made any other changes. I uninstalled it and then re installed it using the manufacturers software. It appears fine until you print. Where do i go from here?
I'm confused about one part. Is it connected by network to all computers? You say you have it as a shared printer, but that would only be the case if it was connected to one computer by USB. If it is all wireless, then it sounds like you need to check on the port your computer is trying to print to.
For any and all network printers, I always hardcode them with a static IP address. This avoids any issues where a new address would get assigned to the printer, leaving some computers unable to connect to it without being reconfigured.
Intel Core i7-2600
Gigabyte GA-P67A-UD3P-B3
Nvidia GTX 470
Dell UltraSharp 2209WA
OCZ ModStream 700W
CoolerMaster HAF 912 Advanced
CoolerMaster Hyper 212 Plus
My apologies. I used the term loosely. The printer is a wireless printer. It is used by all users on the network. How do i do what you said ? I am not the sharpest on these issues. What i don't understand is that it worked fine when i first installed it with the software. Nothing has changed, but it wont print.
There are a couple of different interpretations of "shared" with regard to networked printers.
The first is that the printer is connected to a PC (usually through a USB cable) and that PC shares the printer across the network.
The second is that the printer is connected to a printer server box, or it has a network cable connection of its own, and that printer is shared across the network -- but is not connected to any PC.
Need to know which of these is the case.
Win7 Pro 32-bit, Win8 Pro 32-bitAMD Phenom II X6 1090T4GB ddr3 1300AMD HD 4290 onboard
Gigabyte
4GB ddr3 1300
AMD HD 4290 onboard
Builtin Realtek HD Audio
1920x1200/1920x1080
Kingston 256GB SSD
Logitech Illuminated Keyboard
Logitech M705 wireless mouse
Norton Av 2013
IE v10
"wireless printers" are printers with their own wireless transmitters. I assume it is set up on its own.
I think Deacon Frost's theory has some traction, but I always wired printers as well so I don't know how to give it a static IP, probably from the router's control panel.
Win 7 Pro 64-bit 7601AMD Phenom 9650 QuadCore, revision DR-B35 GB yes I run 2x 2GB and 1x 1GB, different b...NVIDIA GeForce 9800 GT 512 Mb, unknown manufa...
custom built
ASUS M4A78
5 GB yes I run 2x 2GB and 1x 1GB, different brand, spank me.
NVIDIA GeForce 9800 GT 512 Mb, unknown manufacturer.
Crappy Realtek Integrated Audio
Fujitsu Siemens P19-3P
1280 x 1024 x 32 bits @ 60 Hz Oh yeah, 4:3 rocks!
(1) MAXTOR S TM3320613AS SATA Disk Device (2) STM35004 18AS SATA Disk Device (3) TOSHIBA USB 2.5"-HDD
whatever, around 450w
Scavenged from old company PC, 10+ years old
CPU fan, GPU fan, case fan, nothing fancy
Microsoft, PS/2, white.
Optical, logitec.
effective max speeds: 70-ish kB/s down 30-ish kB/s up
Avira, free edition.
Firefox with FXChrome to make it look like Google Chrome :P
Was discarded by previous owner due to "horrible performance".
Was running Win Xp from a IDE drive. Yeah. Was a pain.
SATA II drive and Win7 and it zips away! Yay!
My printer is not connected to a computer. It is all by itself. It communicates through my wireless network.
I don't know if this will help, but I had a similar set up. But, to set it up, I had to connect it by USB to my desktop computer. It went through a process of installing the software, connecting to the router, giving it the password to the router and ensuring it was connected. Then I disconnected the USB and it became a wireless network printer. But, it had to be connected by USB to establish that connection. The computer, (hard wired) had to allow it connection to the router. My understanding was, the other wireless computers in the network could connect wirelessly. The hard wired computer, without wireless capability, has to connect through the router.
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
My experiences with my Fuji Xerox were very similar to Essenbe's - first a wired setup & install, and then the wireless connectivity worked for me.
Golden Mk. I.4
EVGA NVidia GTX 560 1024MB
Realtek Integrated
1920*1080 and 1920*1080
1*Samsung 840 EVO 120GB SSD;
1*OCZ Vertex 2 60GB SSD;
1*Samsung F1 SpinPoint 1TB;
Logitech G110
Logitech MX518
The trick is finding out the address range your router is using for DHCP, such as 192.168.1.100-254 or so. Then, pick something outside of that range. My router is obviously 192.168.1.1, so I made my server 192.168.1.2, and then I hardcoded 192.168.1.3 in for my printer. I also put a label on the printer showing that address, in case I was to forget. Now, once you have that set on the printer, usually on the screen (if it has one), or you may have to connect it to your computer if it doesn't have a screen, any computer on the network should be able to connect to the printer, have the drivers installed, and work fine.
Intel Core i7-2600
Nvidia GTX 470
OCZ ModStream 700W
