hey guys.
i am wanting to install w7 64bit but wen i boot from the cd/dvd it does the whole starting windows thing and then gets to the blue screen with the little bird thing and just stays there. the same thing happens with the 32bit w7.
I have now managed to install the 32bit one but i am still wanting to run 64bit.
If i run the CD from my computer it tells me this:
"This installation disc isnt compatible with your version of windows. To upgrade, you need the correct instalation disc. For more information check your computer's system information. to install a new copy of windows, restart (boot) ur computer using the installation disc, and then select custom (advanced)."
I really dnt kno wat to do now pls can someone help
O and my specs are:
AMD athlon 64 X2 dual core processor 4800+
2 gig ram
Gforce 8500 GT
So im sure i should be able to run 64bit??
O and my specs are:
2 gig ram
Gforce 8500 GT
w7
- w7
