Solved Need Wireless advice for distance networking.
mohavepc
Mohave PC Computers
2:45 PM
Lake Havasu City, Arizona
Hi Guys and Gals
Ok what I am trying to do is network 2 buildings together without digging a trench to bury wire through a parking lot. The two buildings are approx. 60 yards apart with several businesses in between. We need to eliminate separate servers and connect with QuickBooks on 1 server by 4 workstations. there are several options for 14DB antennae and routers with detachable antennae. I am not opposed to outdoor antennae if necessary but I feel that's a bit overkill.
Here's the Router I would like to use and one of the antennae. Question is do I install wireless network adapters in the two machines in the other building or di I find a way to set up another 300mbs router to connect to the first and hard wire the pc's I could use 2 antennae if I go with two routers.
Am I just over thinking this? it's a small network in 2 huge buildings about 100 yards between their furthest points. :shock:
Custom Build MPCBS AMII
Windows 7 Professional x64
AMD Athlon II x4 3.00 GHz
MSI GF615M-p33
16GB Kingston DDR3
Nvidia 8600 (dual DVI out for 2 monitors)
Onboard
Acer H233H 23", ASUS 23"
1366 x 768
(2) WD Blue 1 TB 3 partitions, (1) Seagate 7200 500GB with 2 partitions for useless and frequently deleted data Looking forward do an ssd for os soon.
Corsair 1100Watt
Apevia HAF
HAF AMD High Profile Heat sink and fan
wireless Logitech
wireless Logitech
16 mbps
eSet, AVG, Clam and Clamwin (depends on machine)
(9) Win 7 machines all x64 (POS Updated to Windows 7 pro YEA), (4) Linux machines x64 and x86 including a v3000 compaq lappy brought back to life with Mint 9 used to scan drives, (1) Linux Machine dual boot XP Pro (for testing and destroying), (1) Win 7 pro x64/Win 8.1 Lenovo Laptop Dual Boot.
There are many ways to get this done although for 100 yards distance going through walls to clients you may require something more robust. It may not be possible to cover an entire building with a single A/P.
At that long range setting up a secondary A/P as a bridge or repeater may work better. In bridge mode the A/P turns into a wired access point where you can plug into it from other PC's but it gets the signal from wireless.
There is lots of outdoor specific hardware to choose from.
EnGenius ENH700EXT 802.11n Wireless Outdoor Access Point - Walmart.com
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
ok then how about this used like this?
MSI GF615M-p33
16GB Kingston DDR3
Onboard
1366 x 768
Corsair 1100Watt
Apevia HAF
wireless Logitech
wireless Logitech
16 mbps
I haven't used those but the 5Ghz at only 150Mbps is very slow for wireless AC.
5Ghz with wireless AC is up to 1.3Gbps these days so I'm not sure why this one is only showing 150Mbps.
The 5Ghz band is really only for large open areas, a single AP running this will cover a very large room or outdoor space but won't go through walls and obstacles like the 2.4Ghz will do. That's why it's best to have both.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
