Need Wireless and Wired Running together
Reine
8:48 AM
Hi there,
As the title suggests i need to setup my networks so that they are both working harmoniously together.
The reason i need this is because on the wireless side i need to connect to my router for internet access.
On the wired side i need to connect to my NAS. I have tried connecting the NAS box to the router and it works but it is too slow.
On the hardware side everything works independantly.
I have 2 routers i am using for the job and one is connected to the internet.
Sony Vaio
Win 7 Enterprise
Just wwant to elaborate slightly.
The connections seem to both be connected. but the internet doesn't work.
Could this be because the internet is trying to connect across the wired network?
If so how do i force it to use the wireless connection only?
Sony Vaio
Win 7 Enterprise
You could set the LAN connections default gateway to the IP address of the WLAN Connection, works for me.
Windows 7 Professional x64 Backtrack 4 R2
Intel Core i5-650
Gigabyte P55-UD3
4 GB Geil PC3 12800
HIS HD 4870 X2
Sound Blaster X-Fi Titanium Fatal1ty Champion
BenQ 22" G2220HD
Seagate Barracuda 7200.12 500GB
Antec High Current Gamer 620W Power Supply
Thermaltake Armor+ MX
Microsoft SideWinder X6
Razer Abyssus
Granted i am sharing internet with that WLAN's connection to another computer, that might make a difference.
Intel Core i5-650
Gigabyte P55-UD3
4 GB Geil PC3 12800
HIS HD 4870 X2
BenQ 22" G2220HD
Razer Abyssus
HP Pavilion Elite HPE-410f
AMD Phenom x6 1045t
N/A
8 GB
ATI Radeon HD 5570
Realtek Highdefinition Audio / 5.1 Dolby Setup
HP w2207h Widescreen
1680*1050
1 TB (fixed), 320 Portable maxtor, Server Hard drives
350 Watt
HP CASE
Bass
Logitech MX 5500
Logitech MX 5500
ROAD RUNNER 16MB D/512 U
It would be a good idea if you could draw out a simple diagram of how you have it all connected so that a way forward can be worked out...it should be a fairly simple solution.
win7
