- Local time
- 11:28 AM
- Messages
- 661
When I double-click on a file, instead of opening in the ascribed programme, I get the Properties box. Right-clicking no longer opens a context menu (nothing happens). Menus close as soon as you hover the mouse over them (so I can't access Control Panel or any of its 'subfolders'). The USB keyboard no longer works either - I can highlight (focus) a file, but none of the keyboard inputs are active.
I tried a different mouse, a different keyboard, in different USB ports. I tried System Restore. Still exactly the same.. can't really get into the PC functions at all. :huh:
Then I thought I would try a PS2 keyboard: as soon as I used that to try to open a file, everything suddenly went back to normal!
Now I post this having fixed the problem (far more by luck than by judgement), firstly because the 'solution' may help someone else reading this (if they have a PS2 mouse or keyboard, that is: had I not had one I would by now have been in deepest despair!). And also to ask if any of the resident gurus know what the root of this problem might be - plenty of reports over the web of this kind of thing, dating back over 15 years. I'd love to know what might be happening (must be a hardware issue if a System Restore does not help??).
Seems to me that half my PC problems end up being an issue with USB! Still faulty technology IMHO!
Thanks,
Martin
Thanks,
Martin
Windows 7 Home Premium SP1 64-bitIntel Core i7-4790K CPU @ 4.5GHz16GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz8GB NVIDIA GEFORCE GTX 1070
- Computer type
- PC/Desktop
- Custom Build
- Windows 7 Home Premium SP1 64-bit
- Intel Core i7-4790K CPU @ 4.5GHz
- Motherboard
- Asus H97I-PLUS
- 16GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz
- Graphics Card(s)
- 8GB NVIDIA GEFORCE GTX 1070
- Monitor(s) Displays
- HannsG 28" & Dell 24"
- Screen Resolution
- 1920x1200
- Hard Drives
- 1 x 2TB Samsung Evo 860 SSD
2 x 500GB Samsung Evo 850 SSD
- PSU
- CORSAIR 650W CS SERIES
- Case
- Thermaltake Core V1 Mini ITX Cube
- Cooling
- NOCTUA NH-L12
- Browser
- Firefox
- Other Info
- Custom PC used for X-Plane 11
