Notebook display brightness low when plugging out power cable?
pstein
3:35 PM
As long as the power cable is plugged in in my notebook the brightness of my display is fine.
But when I plug it out and use the battery the brightness becomes suddenly darker.
Why?
How can I prevent this switch-to-dark-screen?
I found no corresponding option in the power plans
Peter
win7pro 64bit
Try going to the Power options and then click Change plan settings for your power plan then in the next window under battery at the bottom is a adjustment for brightness. Be sure to save changes one done.
Jerry
Sager NP9170
Win 7 Pro x64 / Win 10 Pro
CLEVO P170EM
12 GB
Backlite
MSE, Malwarebytes Pro
DESKTOP: Custom-built.
OS: Win 10 Pro x64.
CASE: Rosewill R5.
MOTHERBOARD: Asus Z87-A.
GPU: Nvidia Geforce 650 TI.
PSU: Corsair TX750.
Most laptops remember display brightness with power plugged and brightness when on battery, and switch setting depending on conditions.
So, when display is darker just raise the brightness, and it should remember that in the future.
custom built
Win 7 Pro 64-bit 7601
AMD Phenom 9650 QuadCore, revision DR-B3
ASUS M4A78
5 GB yes I run 2x 2GB and 1x 1GB, different brand, spank me.
NVIDIA GeForce 9800 GT 512 Mb, unknown manufacturer.
Crappy Realtek Integrated Audio
Fujitsu Siemens P19-3P
1280 x 1024 x 32 bits @ 60 Hz Oh yeah, 4:3 rocks!
(1) MAXTOR S TM3320613AS SATA Disk Device (2) STM35004 18AS SATA Disk Device (3) TOSHIBA USB 2.5"-HDD
whatever, around 450w
Scavenged from old company PC, 10+ years old
CPU fan, GPU fan, case fan, nothing fancy
Microsoft, PS/2, white.
Optical, logitec.
effective max speeds: 70-ish kB/s down 30-ish kB/s up
Avira, free edition.
Firefox with FXChrome to make it look like Google Chrome :P
Was discarded by previous owner due to "horrible performance".
Was running Win Xp from a IDE drive. Yeah. Was a pain.
SATA II drive and Win7 and it zips away! Yay!
Hi there .... Most Laptops have function keys to adjust the brightness Press Fn + ... Hope that helps
W530-3630QM1
windows 7 home 64bit
INTEL-CORE I7
16GB
750GB
