Solved Perplexing problem--disappearing place to click
jadinolf
Very Senior Member
Power User
4:12 AM
California
Hi all. This is a tough one to explain and if this is the wrong place to post, let me know.
Here goes--I built a new Windows 7 computer last Saturday (January 5). Here's what happens.
Lets say I am telling Windows 7 to empty the Recycle bin. I "empty the recycle bin" and nothing seems to happen. If I drop the recycle bin window, I see the message "are you sure you want to delete these files".
I am seeing so much of this kind of stuff. I hope I have explained this properly.
I built my first Windows 7 computer last May and have not seen anything like this.
I am at your mercy because I don't have a clue.
Any thoughts?
Thanks for reading this.
Home Built
Windows `10 Professional 64bit
Intel i5 [email protected]
MSI P67A-GD55 (MS7681)
Corsair Vengeance DDR3 1600 16G
NVIDIA GeForce GT520 1GHz
Haans G 241
1600X1024
Crucial MX100 256GB SSD
OCZ ModXStream Modular High Performance 500 Watt
Rosewill Challenger-U3
Just Fans
Kensington K64338B
Microsoft wheel mouse 1.1A
240.0 Mbps
ESET Internet Security
SuperAntiSpyware-Pro
Malwarebytes (Premium)
Kerish Doctor
Windows 7 Professional 64bit
AMD Athlon (tm) X2 5200+ Dual Core 2712 Mhz
Asus
4GB
Nividia GeForce 8600 GTS- DIED 25/7/2013 R.I.P
None
22" Yuraku LCD (Dont ask)
1280x960
2TB WD Caviar green
Windy up type
Scout cm Storm
Hair dryer on full cool power ;-)
QWERTY
Microsoft Special
BT Infinity 9.38Mb/s Wheeeeeeeeeeeeeeee!!
Internet Explore 10 and Chrome
Don't shout...I've got a Hangover!
Thanks Dave. I'll give it a try.
Have never run sfc on Win 7
Home Built
Haans G 241
1600X1024
Just Fans
Kensington K64338B
240.0 Mbps
Kerish Doctor
Ran sfc. No integrity violations found.
Back to the drawing board.
Home Built
Haans G 241
1600X1024
Just Fans
Kensington K64338B
240.0 Mbps
Kerish Doctor
Hey Jadinolf,
Thats good that no integrity violations were found :)
Ok..this is a solution you may try to resolve the recycle bin issue (as i dont know your other issues?):
IMPORTANT: The following procedure permanently deletes all files and folders which are already in the Recycle Bin (from all user accounts in the system) and cannot be recovered.
1. Same as before:
Click on the start button> Type CMD on Search
Right click CMD and Run as Administrator
2. Type the following command and press ENTER:
rd /s /q C:\$Recycle.bin (just copy and paste this as its easier)
This will clear out the $Recycle.bin folder from the C:\ partition. If you have more than one partition you might have to do this for each hard drive partition in your system.)
Type exit to close the Command Prompt window.
Reboot and check recylce bin operation
If that does not do the trick, you can try Ccleaner, which incudes that very function.
http://www.piriform.com/ccleaner/builds
Give that a try and let me know.
You may also want to check what programs are running in the backgound and uninstall any you never use:
http://windows.microsoft.com/en-GB/windows7/Optimize-Windows-7-for-better-performance
Cheers
Dave
Asus
4GB
None
1280x960
2TB WD Caviar green
Windy up type
Scout cm Storm
QWERTY
Microsoft Special
OK, Dave. Thanks.
I'm tied up with another problem on another computer but I'll get to this.
Stand by.:)
Home Built
Haans G 241
1600X1024
Just Fans
Kensington K64338B
240.0 Mbps
Kerish Doctor
Well, the problem seems to have disappeared.
Can't believe it solved itself but it's working properly.
Thanks all.
Home Built
Haans G 241
1600X1024
Just Fans
Kensington K64338B
240.0 Mbps
Kerish Doctor
Thanks all.
Hey no problem,
Maybes something you did managed to resolve it, or maybe a glitch...who knows.:confused:
Glad your sorted, can mark this thread solved please. And feel free to pop back anytime if you have any more queries or questions.
Cheers
Dave :thumbsup:
Asus
4GB
None
1280x960
2TB WD Caviar green
Windy up type
Scout cm Storm
QWERTY
Microsoft Special
Thanks all.
Hey no problem,
Cheers
Dave :thumbsup:
Oh I will pop in - that's for sure.
I have tried duplicating the problem several times this morning. Won't do it.
Home Built
Haans G 241
1600X1024
Just Fans
Kensington K64338B
240.0 Mbps
Kerish Doctor
Thanks all.
Hey no problem,
Cheers
Dave :thumbsup:
Hmmm, maybe the SFC worked :D
Anyway enjoy
Cheers Dave
Asus
4GB
None
1280x960
2TB WD Caviar green
Windy up type
Scout cm Storm
QWERTY
Microsoft Special
