You should upgrade or use an
alternative browser .
Philips Brand New screen build in sound does not work, HELP!!!
Window 7 Ultimate 32bit Intel core 2 duo @ 2.40 Ghz Hynix 2X1GB The Club 3D GTS250 256bit Computer Manufacturer/Model NumberGigabyte OSWindow 7 Ultimate 32bit CPUIntel core 2 duo @ 2.40 Ghz MotherboardGigabyte MemoryHynix 2X1GB Graphics Card(s)The Club 3D GTS250 256bit Sound Cardlaptech Monitor(s) DisplaysAcer Screen Resolution1440X900 Hard DrivesSeagate 350gig
Seagate 250gig PSUCoolermaster GX 650 CaseAcer Cooling2 80mm fans KeyboardAcer MouseLogitech Internet Speed54kb/s
Windows 10 Pro x64, Arch Linux Intel Core 2 Quad Q8200 OC'd 3.08GHz 8GB DDR2 900Mhz MSI GT730 2GB GDDR5 (Kepler) Computer typePC/Desktop Computer Manufacturer/Model NumberCustom Build OSWindows 10 Pro x64, Arch Linux CPUIntel Core 2 Quad Q8200 OC'd 3.08GHz MotherboardAsus Rampage formula LGA775 Memory8GB DDR2 900Mhz Graphics Card(s)MSI GT730 2GB GDDR5 (Kepler) Sound CardSupreme FX2 Monitor(s) DisplaysSamsung LS22F350 LED Screen Resolution1080P Hard DrivesKingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch) PSUAeroCool 500W Bronze CoolingCooler Master V6 + 3X fans KeyboardProlink keyboard MouseLogitech M705 Internet Speed1MiB/s BrowserChrome Beta
oky how do you install this by going to the device manger?
1. Extract the 3 files to a folder
2. Go to device manager(Start>Type 'device manger' in search)
3. select your monitor>click on update>'browse my computer for driver software'>Browse location of folder containing the 3 files
4. Click 'Next'
24.7 KB
12.8 KB
I have done this mate no sound
Restart your computer after installing the drivers
If there is still no sound Then go to Control Panel>Hardware and Sound>Sound
Then Set your Built in speakers as the default device
witch one is the build in?
18.9 KB
Your speakers are already set to default
Perhaps your speakers have not been properly configured.
74669d1274716083-philips-brand-new-screen-build-sound-does-not-work-help-untitled.jpg
19.3 KB
That is just a tester mate and it doesn't help me because I hear no sound
31.5 KB
31.5 KB
38 KB
