Please help a Newb with Rainbow Screen BSOD Problem
Wish & LiquidSnak,
Changes made, as per your info...
With regards to the WINTV, this card has been part of the system since Original Build (when OS was Media Centre).
I don't actually have WIN TV software installed, so can I get rid of these drivers (what would be the best way to do it)?
Fujitsu Siemens Scaleo P
Windows 7 Ultimate 32 bit
Intel P4 Dual 3.20 GHz
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
ST3200827AS ATA 2x250GB
Go into device manager from the control panel and uninstall & delete the driver. It should be under there.
After that, shut down the computer, remove the hardware, and let us know if that fixes the problem.
Pugh Technologies
W7 Professional x64
AMD Athlon II X3 445 Rana 3.10 GHz
MSI 870A-G54
PNY XLR DDR3 1600 4x2GB
NVIDIA GeForce GTS 450 (fermi) 1GB GDDR5
Realtek ALC892 onboard
ASUS VE205t, Viewsonic VX2035WM
1600x900, 1600x1050
977GB Hitachi Hitachi HDS721010CLA332
244GB Western Digital WDC WD2500AAJS-65B4A0
488GB Western Digital WDC WD5000AAJS-00A8B0
488GB Western Digital WDC WD5000AAKS-00UU3A0
Antec EarthWatts EA650 650W
ThermalTake Armor A90 Mid Tower
3x 120mm in, 1x 120mm & 200mm out, self built hydro-cooler
Logitec 55
Razer Deathadder
20 Mbps D/L, 9 Mbps U/L
Okay, done..
However, now I'm getting the little yellow warning triangles under my CD & DVD Drives with the message 'Cannot load the device driver for this hardware'.
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
Are they the drivers for your CD/DVD drive? If so, I would uninstall via device manager and then click "scan for hardware changes"
Pugh Technologies
W7 Professional x64
MSI 870A-G54
1600x900, 1600x1050
Logitec 55
Razer Deathadder
Okay, done..
Are you use any burning software?
After rename 2 drivers from CD/DVD burning software, it'll break the software.(You may rename it back to make the software work again)
But I think it's better to uninstall the software related and install win7 compatible burning software.
cdrbsdrv.SYS Mon Feb 20 17:17:38 2006 --> CD-ROM Filter Driver for B's   Recorder GOLD (update no longer available)
pcouffin.sys Tue Dec 05 21:39:53 2006 --> [URL="http://www.vso-software.fr/"]CD/DVD burning   programs [/URL]
FYI your CD/DVD device could work fine if it load win7 driver --> cdrom.sys
cdrom.sys    Tue Jul 14 06:11:24 2009
AMD A10-5800K
ECS A55F2-M3
4.00GB Dual-Channel DDR3
ATI AMD Radeon HD 7660D
Steelseries Siberia
1366x768
WDC 3 TB
Seagate 500 GB
2 Mbps
And lo, after making all the relevant changes, the BSOD's keep coming...
:cry:
Here's today's Report:-
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
I know it's frustrating, but hang in there. We'll get you sorted out :)
Pugh Technologies
W7 Professional x64
MSI 870A-G54
1600x900, 1600x1050
Logitec 55
Razer Deathadder
Yeah, SOMEBODY must have the answers.
I have sorted the issue with my DVD Drives, so just waiting for the final piece of the puzzle to fall into place.
Fingers Crossed.
S
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
Your Realtek network drivers should be updated. Install these ones: Realtek
Your modem drivers are out of date as well, so start here: Conexant: Modem Driver Assistance
Now your CD/DVD drive seems to be erroring. You are getting error 39 in Device Manager:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.
Now Windows usually uses generic drivers for ATAPI devices, why would they be corrupted or missing?
Just to make sure, run a system files check. Open an elevated command prompt and enter sfc /scannow.
More likely than a driver issue is a hardware error, honestly. Both of your optical drives are erroring, according to msinfo32. In addition, your USB hard drive (Seagate FreeAgent) seems to be having trouble:
Event[558]:
  Log Name: System
  Source: Disk
  Date: 2010-10-21T20:16:13.833
  Event ID: 11
  Task: N/A
  Level: Error
  Opcode: N/A
  Keyword: Classic
  User: N/A
  User Name: N/A
  Computer: Stephen-PC
  Description:
The driver detected a controller error on \Device\Harddisk2\DR2.
Event[4466]:
  Log Name: System
  Source: Disk
  Date: 2010-10-19T15:16:23.476
  Event ID: 11
  Task: N/A
  Level: Error
  Opcode: N/A
  Keyword: Classic
  User: N/A
  User Name: N/A
  Description:
Event[34998]:
  Log Name: System
  Source: Disk
  Date: 2010-09-03T02:01:27.476
  Event ID: 11
  Task: N/A
  Level: Error
  Opcode: N/A
  Keyword: Classic
  User: N/A
  User Name: N/A
  Description:
We also have some of these:
Event[34951]:
  Log Name: System
  Source: Microsoft-Windows-Kernel-Processor-Power
  Date: 2010-09-03T12:07:29.765
  Event ID: 6
  Task: N/A
  Level: Error
  Opcode: Info
  Keyword: N/A
  User: S-1-5-18
  User Name: NT AUTHORITY\SYSTEM
  Description:
Some processor performance power management features have been disabled due to a known firmware problem. Check with the computer manufacturer for updated firmware.
And something curious:
Event[805]:
  Log Name: System
  Source: Microsoft-Windows-WER-SystemErrorReporting
  Date: 2010-10-21T19:05:58.000
  Event ID: 1005
  Task: N/A
  Level: Error
  Opcode: N/A
  Keyword: Classic
  User: N/A
  User Name: N/A
  Computer: STEPHEN-PC
  Description:
Unable to produce a minidump file from the full dump file.
Your TV Tuner drivers are out of date:
hcw88aud.sys Fri Jul 10 10:35:04 2009 (4A575198)
HCW88BAR.sys Fri Jul 10 10:35:03 2009 (4A575197)
hcw88bda.sys Fri Jul 10 12:37:19 2009 (4A576E3F)
hcw88tse.sys Fri Jul 10 10:35:10 2009 (4A57519E)
hcw88tun.sys Fri Jul 10 10:35:08 2009 (4A57519C)
hcw88vid.sys Fri Jul 10 10:35:18 2009 (4A5751A6)
I'm wondering if that could be conflicting. Try uninstalling the drivers, and installing a fresh, updated copy.
Remove the Seagate drive for now. I don't know what to make of the failed minidumps, honestly. Could be another sign of bad hardware, but then, maybe not.
If possible, remove both of your DVD drives. Of course, you will need them someday, sooner or later depending on how much you use optical media. Just see if the BSODs stop.
...Summary of the Dumps:
[FONT=lucida console]
Built by: 7600.20738.x86fre.win7_ldr.100618-1621
Debug session time: Fri Oct 22 04:27:57.337 2010 (UTC - 4:00)
System Uptime: 0 days 0:56:47.650
BugCheck A, {18, 2, 0, 8306c132}
Probably caused by : ntkrnlmp.exe ( nt!KiUnlinkWaitBlocks+b )
BUGCHECK_STR:  0xA
PROCESS_NAME:  iexplore.exe
[/FONT]
Windows 7 Professional x64
Intel i7 2600K OC'd @ 4620 MHz
Asus P8Z68-V Pro
16GB GSkill Sniper 2133 Mhz (4x4GB)
EVGA GeForce GTX 480 SuperClocked+
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
Hi -
System files show -
[FONT=lucida console]Original Install Date:     15/12/2009, 12:00:14[/FONT]
The earliest timestamp on the 15 mini kernel memory dumps from the various attachments = 28 September 2010. Were there any BSODs or other system trouble during the preceeding 9.5 months?
11 of the 15 BSODs occurred just under 13 seconds after boot-up -
[FONT=lucida console]System Uptime: 0 days 0:56:47.650[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:10.312[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:11.000[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:14.109[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:11.406[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:12.781[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:12.656[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:15.031[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:12.859[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:18:44.204[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:25:48.393[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:55.046[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:28.312[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:16.812[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:03:49.156[/FONT]
BIOS is a likely problem here -
[FONT=lucida console]Win32_BIOS.Name="BIOS Date: [COLOR=red]11/28/05[/COLOR] 10:37:03 Ver: 08.00.10",[/FONT]
[FONT=lucida console]SoftwareElementState=3,TargetOperatingSystem=0,Version="[COLOR=purple][B]DELL[/B][/COLOR] - 11000528"  [/FONT]
Your system = Fujitsu Siemens P5GD1-FM. I don't know the significance of DELL mentioned in the BIOS by WMI.
Fujitsu specs show your system has an Asus P5GD1-FM motherboard - http://uk.ts.fujitsu.com/rl/service.../Motherboards/asus/P5GD1-FM/asus-P5GD1-FM.pdf
You have two identical 200 GB internal HDDs - ST3200827AS ATA Device
- Run chkdsk /r on all drives
- Run HDD Diagnostics on both - Start with SeaTools for DOS - HDD Diag
Given issues with cdrom.sys , I would remove this 2002 CD burning app -
[FONT=lucida console]aspi32.sys   Wed Jul 17 12:05:08 [COLOR=red]2002 [/COLOR](3D3595B4) - Adaptec CD burning - [URL="http://www.adaptec.com/en-US/downloads/"]Adaptec - Technical Support[/URL][/FONT]
System logs show app hangs and crashes began in December 2009 - iTunes was the first to crash.
Run --> Windows 7 Upgrade Advisor - see whay it has to say.
Windbg Logs
--> http://jcgriff2.net/BSOD_Logs/_99-dbug_Woodssi_Windows7x86_10-23-2010_jcgriff2_.txt
--> http://jcgriff2.net/BSOD_Logs/_99-dbug_Woodssi_Windows7x86_10-23-2010_jcgriff2_.txt.zip
Regards. . .
jcgriff2
BSOD BUGCHECK SUMMARY
[FONT=lucida console]Built by: 7600.20738.x86fre.win7_ldr.100618-1621[/FONT]
[FONT=lucida console]Debug session time: Fri Oct 22 04:27:57.337 2010 (GMT-4)[/FONT]
[FONT=lucida console]Probably caused by : ntkrnlmp.exe ( nt!KiUnlinkWaitBlocks+b )[/FONT]
[FONT=lucida console]DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0xA[/FONT]
[FONT=lucida console]PROCESS_NAME:  iexplore.exe[/FONT]
[FONT=lucida console]Bugcheck code 0000000A[/FONT]
[FONT=lucida console]Arguments 00000018 00000002 00000000 8306c132[/FONT]
[FONT=lucida console]¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨``[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 13:55:30.843 2010 (GMT-4)[/FONT]
[FONT=lucida console]*** WARNING: Unable to verify timestamp for atikmdag.sys[/FONT]
[FONT=lucida console]*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys[/FONT]
[FONT=lucida console]*** WARNING: Unable to verify timestamp for dxgkrnl.sys[/FONT]
[FONT=lucida console]*** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0xc9_c[/FONT]
[FONT=lucida console]DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP[/FONT]
[FONT=lucida console]PROCESS_NAME:  System[/FONT]
[FONT=lucida console]Bugcheck code 000000C9[/FONT]
[FONT=lucida console]Arguments 0000000c 80e4d43c 8997cf68 00000000[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 05:30:26.531 2010 (GMT-4)[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0xc9_22e[/FONT]
[FONT=lucida console]Arguments 0000022e 8fe8b1c2 93ba0f00 00000000[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 05:27:26.640 2010 (GMT-4)[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0xc9_23b[/FONT]
[FONT=lucida console]Arguments 0000023b 8fe8f1c2 93540eb8 00000000[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 05:18:41.937 2010 (GMT-4)[/FONT]
[FONT=lucida console]Arguments 0000022e 8fea31c2 949c4f00 00000000[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 05:12:51.312 2010 (GMT-4)[/FONT]
[FONT=lucida console]*** WARNING: Unable to verify timestamp for ks.sys[/FONT]
[FONT=lucida console]*** ERROR: Module load completed but symbols could not be loaded for ks.sys[/FONT]
[FONT=lucida console]*** WARNING: Unable to verify timestamp for hcw88bda.sys[/FONT]
[FONT=lucida console]*** ERROR: Module load completed but symbols could not be loaded for hcw88bda.sys[/FONT]
[FONT=lucida console]Arguments 0000023b 8fe771c2 93aaeeb8 00000000[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 05:09:03.187 2010 (GMT-4)[/FONT]
[FONT=lucida console]Arguments 0000023b 8fe8a1c2 94e46eb8 00000000[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 04:56:45.593 2010 (GMT-4)[/FONT]
[FONT=lucida console]Arguments 0000022e 8fe991c2 899e4f00 00000000[/FONT]
[FONT=lucida console]Debug session time: Thu Oct 21 04:35:18.406 2010 (GMT-4)[/FONT]
[FONT=lucida console]Arguments 0000022e 9027e1c2 90c50f00 00000000[/FONT]
[FONT=lucida console]Debug session time: Mon Oct 18 14:57:33.922 2010 (GMT-4)[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0x50[/FONT]
[FONT=lucida console]Bugcheck code 00000050[/FONT]
[FONT=lucida console]Arguments ffffffe8 00000001 83096448 00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Sep 29 04:49:35.096 2010 (GMT-4)[/FONT]
[FONT=lucida console]BugCheck D1, {5, a, 0, 96150b71}[/FONT]
[FONT=lucida console]Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiUpdateContextRunningTimeAtISR+89 )[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0xD1[/FONT]
[FONT=lucida console]Bugcheck code 000000D1[/FONT]
[FONT=lucida console]Arguments 00000005 0000000a 00000000 96150b71[/FONT]
[FONT=lucida console]Debug session time: Wed Sep 29 03:22:42.750 2010 (GMT-4)[/FONT]
[FONT=lucida console]Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiUpdateContextStatus+1b8 )[/FONT]
[FONT=lucida console]PROCESS_NAME:  csrss.exe[/FONT]
[FONT=lucida console]Arguments 00000000 00000002 00000001 8306b4e6[/FONT]
[FONT=lucida console]Debug session time: Wed Sep 29 03:14:19.000 2010 (GMT-4)[/FONT]
[FONT=lucida console]Probably caused by : Ntfs.sys ( Ntfs!NtfsFastIoDispatch+c )[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0x8E[/FONT]
[FONT=lucida console]PROCESS_NAME:  explorer.exe[/FONT]
[FONT=lucida console]Bugcheck code 1000008E[/FONT]
[FONT=lucida console]Arguments c0000005 8c06990c 9d648990 00000000[/FONT]
[FONT=lucida console]Debug session time: Tue Sep 28 18:14:19.359 2010 (GMT-4)[/FONT]
[FONT=lucida console]Arguments 0000022e 8fe7e1c2 90a34f00 00000000[/FONT]
[FONT=lucida console]Debug session time: Tue Sep 28 06:56:18.843 2010 (GMT-4)[/FONT]
[FONT=lucida console]Probably caused by : ntkrnlmp.exe ( nt!KiTryUnwaitThread+46 )[/FONT]
[FONT=lucida console]Arguments 000000ba 00000002 00000001 830a3572[/FONT]
[FONT=lucida console]by [COLOR=navy]jcgriff2     [/COLOR][/FONT]
[FONT=lucida console][COLOR=navy]       J. C. Griffith, Microsoft MVP[/COLOR]   [/FONT]
[FONT=lucida console]         [URL="https://mvp.support.microsoft.com/profile/Griffith"][COLOR=#000055][U]https://mvp.support.microsoft.com/profile/Griffith[/U][/COLOR][/URL]   [/FONT]
[FONT=lucida console]         [URL="http://www.jcgriff2.com"][COLOR=#000055][U]www.jcgriff2.com[/U][/COLOR][/URL] [/FONT]
[FONT=lucida console]¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨[/FONT]
Windows 7 - Vista
Jon,
Done
The Site only has Drivers up to WinXP, nothing for Windows 7
Now your CD/DVD drive seems to be erroring. You are getting error 39 in Device Manager - 'Windows cannot load the device driver for this hardware. The driver may be corrupted or missing'.
I have updated the Controllers through Microsoft Site, and all now appears fine.
Done, no issues highlighted.
Your USB hard drive (Seagate FreeAgent) seems to be having trouble.
I have now done an Uninstall / Reinstall of the appropriate Software
Your TV Tuner drivers are out of date.
I no longer use TV Tuner (since OS Media Centre). Can I just delete these (or do I need a specific program to uninstall them)?
Thanks for your assistance
Stephen
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
JC,
System files show -
Nothing at all like this through Media Centre, then XP Pro, and now 7 Ultimate.
I had a look at the ASUS Updater, but it mentions I need a Floppy DD (which my System doesn't have). Is there another option?
Done, with no issues highlighted (although this was after I updated the Controllers through the Microsoft Support site).
[FONT=lucida console]aspi32.sys   Wed Jul 17 12:05:08 [COLOR=red]2002 [/COLOR](3D3595B4)[/FONT]
I cannot find this Software at all (I use IMGBurn now anyways). How can I delete or Uninstall this Driver?
Done, and all shows as Compatible, with no other issues highlighted.
I have attached a more recent Report, given the Updates / Changes I've made (from replies from both Jon & yourself).
Much obliged for your assistance.
Stephen
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
And here's the dmp from the first BSOD since I made the above changes....
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
Has the BIOS issue been addressed yet?
Some systems simply cannot run Windows 7 and maintain stability.
Per Microsoft -
... for those running a Windows OS other than Vista,
we recommend that you experience Windows 7 on a new system....
Regards. . .
jcgriff2
Windows 7 - Vista
JC,
How do I update BIOS without a Floppy DD?
I've been running Windows 7 for well over a year. The issues have only started within the last Month.
A new BSOD message came up today:-
'The Driver is mismanaging PTEs'....
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
Pugh Technologies
W7 Professional x64
MSI 870A-G54
1600x900, 1600x1050
Logitec 55
Razer Deathadder
Windows 7 - Vista
JC,
Yep, appears there is no more up-to-date BIOS for my particular PC.
As far as I can tell, everything else (Drivers wise) has been updated.
Still no reply as to how best to get rid of the aspi32 & Hauppage Drivers...
If anything else springs to mind, I'd be obliged.
Stephen
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
Stephen... If all else fails, rename the drivers with a .bak extension ie: hcw88aud.bak ... that way they will not load on boot... ;)
LENOVO K450 @3.0GHZ
64-bit Windows 8.1 Pro
LENOVO
12.00 GB
Intel(R) HD Graphics
Intel HD integtrated
HP 25' ISP Monitor
100mb down/10mb up
Tews, I've done that... will see how the old girl handles now.
Other than that, guess I better start saving for a new System.
I'd, once again, like to thank all who posted replies. If I haven't given anyone the proper Reputation, let me know.
Stephen
ASUS P5GD 1-FM
3MB DDR RAM
RADEON X700/X550
Intel 82801FB ICH6
Generic PnP Monitor
