Please help me out of these problems or i wİll go mad
Kuby
10:42 PM
Hello Guys: ı have just formated my laptop and istall drivers and neccessary programs to the C: Drive. (Well when ı installing drivers ı have notice the laptop went so slow)
Then Now ı want to install Linux to my my D: drive. To do this ı have incerted my Flash disk, opened my Ultraİso, Chose "Write Bootable Disk image" as usual. and now; first ı wanted to format flash disk, and ı had "This drive in use. Another program or process is using this drive" false. But anyway ı did format it then ı have pushed the button writtig "WRİTE" and now ı am seen a message such as "The Device is busy. Close all running applications. Click on OK Button to Retry"
AND: When ever ı run "Rate my Computer"
I can not rate my laptop in performance and tools window. İt says " The Windows Experience İndex for your system couldn't be computed. Can not complate assessment."
Last and MOST important problem of me in windows 7 is ı do not want to receive any message as "Access Denied"
ı am usually having this message. Well there is NO ONE is using my laptop except me but anyway ı am having thi message too. ı have already went to the security and changed and inherit permittions.
Unfortunately Acer
I use unetbootin, works in windows and in linux.
It should be able to write the linux installer to the usb flash drive.
UNetbootin - Homepage and Downloads
Run it and direct the unetbootin to the iso of linux you downloaded.
Then boot the liveusb unetbooting created on the flash drive.
Then when you run the linux installer, tell it to install to that D: drive, of course it wont say it is D:
Perhaps an antivirus program is scanning the usb drive while your trying to write to it?
Thank you. ı will try it. well ı knew this tool but ı havent use it ı was using Ultraİso. so can you say please how can ı rid of seen "Acces denied" message? My friend There is NO ONE using my laptop and the 7 keep saying me "Access denied" well went to the security tab and try to own and inherit permittion but NO RESULT
Unfortunately Acer
start in safe mode and see if you can access it.
Hi and welcome to SevenForums,
I personally used Linux universal usb installer if formats the stick for you
The only issue usually with installing Linux to a partition is if windows has the 100mb system reserved partition as well as C.
Custom assembled by me :}
Win-7-Pro64bit 7-H-Prem-64bit
Built-in Realtek
2-Samsung M.2 Evo & Evo Plus
Custom water loops
FireFox & Pale moon
The user's Administrator account is outranked by other "System users" (i.e. you don't have full control over your PC).
A few days ago I was trying to do something and I couldn't, despite the Security tab clearly showing that the Administrators Group Permissions were set to "Full control".
I'm not a fan of the Linux Permission system, but when you switch to "root" (Administrator) you are "the Supreme Authority".
W7 Ultimate SP1, LM19.2 MATE, W10 Home 1703, ...AMD Phenom II x6 1100T, 3.3 GHz12GB DDR3 1333 G-Skill (4GB x 2), G-Skill (2G...NVIDIA GeForce GTX 660
n/a
ASUS M4A88T-M/USB3 (AM3)
Realtek?
Samsung S23B350
Cooler Master
Antec GX300 Tower
3x Antec TRICOOL 120mm Fans
Wired Optical
DSL
Pale Moon (64 bit)
2018-12-27 Upgraded HDDs
Thank you my friends. Well actually ı am having this annoying message (Access denied) When ever ı run Jarvis (a voice reconition program) and also ı am having this message too
Unfortunately Acer
How can i turn off all the securİty:
My friends what ever ı do with my laptop ı am having the same message "Access Denied"
Unfortunately Acer
Windows 7 Ultimate 64bit Service Pack 1Intel core i5 2500K Sandy Bridge overclock @ ...G Skill Ripjaws X 2 X 2 gigabyteSapphire AMD Radeon HD 6870 Toxic edition ove...
All around gaming desktop
Intel core i5 2500K Sandy Bridge overclock @ 4.2 Ghz
Gigabyte Z68MA D2H B3
Sapphire AMD Radeon HD 6870 Toxic edition overclock @ 970 Mh
built in
Samsung 23" S23A300B LED
1920 X 1080 pixels
WD Caviar Black 640 gb. Systems disk
WD Caviar Blue 500 gb. Storage disk
Corsair HX 650 watts power supply
Antec 300 AB black edition modded
Cooler master V6 gt CPU cooler
Logitech G110
Logitech mx 518
768 kbps
GameWarNow!
I don't believe we can actually say how to put your computer at risk :/
You might say what security is on this machine and exactly where and what locations are you getting these access denied messages and doing what tasks.
Built-in Realtek
Custom water loops
FireFox & Pale moon
Reformat your laptop , it might been compromised by a malware that controlled ur account ...
https://support.microsoft.com/en-us/kb/2623670
That is rather draconian. We don't know yet if it is malware and, if it is, there is a good chance it can be purged without resorting to formatting and reinstalling the OS, etc. In fact, formatting and reinstalling the OS may not work if the malware is lurking in the data or a software or driver installation file which would simply reintroduce it.
Win 7 Ultimate 64 bit
Intel i7-3930K
ASUS P9X79 WS
Asus Xonar Essence STX
1920 x 1080, ?
Samsung 4TB 850 EVO SSDs (4)
Corsair HX750w
Logitech G510s
Logitech M525 (two in use)
=< 32Mbps down, 8Mbps up
IE11
