Solved Please help me with Batch, need manual input required see description
lewisaro
2:09 PM
Hi there,
I am trying to create a batch file which will use the command nbtstat-a and then request the IP of the user within the same line (e.g. nbtstat-a *please enter the target IP to lookup*) to look up the machine name of a computer on the network, the only problem is that i dont know how to make it so that the first part is automatically filled out (nbtstat -a) then the user has to input the IP address to continue.
Please could anyone help?
Thanks :) Much Appreciated
windows 7 pro 64bitIntel 3570k12GBgtx 660
windows 7 pro 64bit
Intel 3570k
asus maximus v gene
12GB
gtx 660
2x 1TB WD
1x SSD
avast
icedragon
Welcome to Seven Forums
To concatenate commands use the & symbol.
For example, Command A & Command B
Try this.
set /p id="Enter IP Address: " & nbtstat -a %id%
Tanya
Linux Mint 17 Cinnamon | Win 7 Ult x64Intel I7-3770K @ 4.2ghz32GB G-Skill C10QEVGA GTX 670 2GB SC
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
Creative Fatality ExtremeGamer
LG E2742V x 2
256GB Vertex 4 SSD
2TB Seagate ST2000DM001
1TB Seagate ST1000DM003
Corsair HX 650
HAF 932 advanced
Corsair H100i liquid cooler
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
Router: Sagemcom F@st 3846 Crippled by Optus.
Brilliant! thankyou so much :D
windows 7 pro 64bit
Intel 3570k
asus maximus v gene
12GB
gtx 660
2x 1TB WD
1x SSD
avast
icedragon
I have managed to get the command working when I ping an IP address however when I do nbtstat -a it just loops back to the start and I am unable to do the lookup, I have tried doing timeouts and goto command but it still doesn't seem to work! what am i doing wrong?:(
windows 7 pro 64bit
Intel 3570k
asus maximus v gene
12GB
gtx 660
2x 1TB WD
1x SSD
avast
icedragon
Can you post your batch file, please
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
this is what I have so far:
@ECHO OFF
set /p "id=Please enter an IP address: "
cls
Ping %ID%
nbtstat -a %id%
it successfully pings however it doesn't do the nbtstat look up it just jumps back "please enter an IP address"
windows 7 pro 64bit
Intel 3570k
asus maximus v gene
12GB
gtx 660
2x 1TB WD
1x SSD
avast
icedragon
Ok, that looks fine to me.
And indeed, it runs perfectly for me.
Here's the output.
Pinging 192.168.1.2 with 32 bytes of data:
Reply from 192.168.1.2: bytes=32 time=2ms TTL=128
Reply from 192.168.1.2: bytes=32 time=1ms TTL=128
Ping statistics for 192.168.1.2:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 2ms, Average = 1ms
Local Area Connection:
Node IpAddress: [192.168.1.2] Scope Id: []
           NetBIOS Remote Machine Name Table
       Name               Type         Status
    WORKGROUP      <00>  GROUP       Registered
    TANYA-PC       <00>  UNIQUE      Registered
    TANYA-PC       <20>  UNIQUE      Registered
    WORKGROUP      <1E>  GROUP       Registered
    WORKGROUP      <1D>  UNIQUE      Registered
    ..__MSBROWSE__.<01>  GROUP       Registered
    MAC Address = BC-5F-F4-45-5C-B8
I ran it from my desktop, then from my C:\ drive, then as a scheduled task. It worked perfectly every time. I even ran it from within another cmd file, and then "called" it from within another cmd file. Works every time.
So, how are you running it?
Tanya
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
Ive tried it from desktop and c drive and it still loops
http://postimg.org/image/en98ot5jz/ thats whats happening :(
I have full admin permission so thats not the problem either
windows 7 pro 64bit
Intel 3570k
asus maximus v gene
12GB
gtx 660
2x 1TB WD
1x SSD
avast
icedragon
Well, I've spent the last day trying to recreate your problem. Tried it on XP, Windows 7, Windows 8 and 8.1. I tried it on a standard user account, and an administrator account. No matter what I do I can't recreate the problem you're having. This is really bizarre :confused:
I'll keep digging and trying different things....
Meanwhile, if any other knowledgeable people are passing by hopefully they will chime in..
btw, should probably add "Set id=" (minus the quotes) as the last line just to clean up after. That will delete the environment variable.
Tanya
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
Hi Tanya, I really appreciate that you have been helping and tried so many ways to get around the issue!
ive had the thought, would the issue be occurring due to the fact that im on a domain?
will add that line now:)
Thanks again for all the help!
-Lewis
windows 7 pro 64bit
Intel 3570k
asus maximus v gene
12GB
gtx 660
2x 1TB WD
1x SSD
avast
icedragon
Hi Lewis,
Not sure about the domain side of things. It's been a decade since I worked with domains/active directory and a lot has changed over the years. With most of my machines now converted to Linux, I'm going to find it difficult to test a domain scenario.
However, based on past experience, I don't see why being a member of a domain would make a lot of difference. The machine could be locked down by policy, but (and I could be forgetting something here), I don't think there is anything there that would cause this type of behavior.
I got a couple of friends to test the script and it worked fine for them. I'll see if I can track down some old contacts that are on a domain and see it they can test it for me too.
Just out of curiosity, you haven't named the batch file ping.bat or nbtstat.bat have you (or ping.cmd/nbtstat.cmd).. That will cause a mess ;)
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
Hi Lewis,
I cant believe it! I had it named nbtstat.bat all along and renaming it fixed it! Thankyou so much for your help!! I appreciate it a ton!
windows 7 pro 64bit
Intel 3570k
asus maximus v gene
12GB
gtx 660
2x 1TB WD
1x SSD
avast
icedragon
:party:
calling a batch file by the same name it contains a command for would cause it to loop. So nbtstat.bat would simply keep calling nbtstat.bat from within the batch file.
Have fun.
Tanya
Home Made
ASRock Extreme 4
32GB G-Skill C10Q
EVGA GTX 670 2GB SC
LG E2742V x 2
256GB Vertex 4 SSD
Corsair HX 650
HAF 932 advanced
Logitech Wireless
Logitech Wireless
OptusNet NBN 100/40
Malwarebytes
Firefox 30
