Power save problem
vdurieu
9:26 PM
Hello
I run seven home on a laptop toshiba a100-590
i select the power plan 'balanced' with 'put computer to sleep' = never when plugged & on battery.
however, the laptop goes to standby after x time when plugged.
when not plugged, the indicator says 'no battery detected'
what can I do ?
thanks
Windows seven
Does the battery really work? Try updating the drivers for your battery. Did you check out the Hibernate option? Maybe the laptop is not going into sleep, but hibernation.
Windows 7 Professional x64
Intel i7 2600K OC'd @ 4620 MHz
Asus P8Z68-V Pro
16GB GSkill Sniper 2133 Mhz (4x4GB)
EVGA GeForce GTX 480 SuperClocked+
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
