Printer problem help please
dekano
12:42 PM
hey guys i have a HP deskjet d1560 but the drivers or not installing it says it's just gives on error in the middle of the installation.
windows 7
SELF BUILT
Windows 7 RC Build7100
AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
MSI K9AGM2
2.00GB
Radeon X1650 Series
Real TEK
Westing House 22" Wide screen
120 Gigabyte Segate Baracuda
Thermal take True Power Trio 750 Watts
Cooler Master Lite
Default what it comes it
Logitech Y-SAB59 Elite Keyboard LE
Logitech MX Revolution (Laptop Edition)
DSL 3.5 Down / 768 Up
SELF BUILT
MSI K9AGM2
2.00GB
Radeon X1650 Series
Real TEK
Cooler Master Lite
printer offline
Hello,
I have a serious problem with my network printer. It is a small office printer HP laserjet 1200 PCL5 connected to network, works fine with XP and vista. Unfortunately, with Windows 7 it does not work.
The computer itself does not find neither the printer or its IP adress (from command prompt ping printers IP works). However if I install the drivers manually and set up the printer it creates the printer icon. Everything looks fine until I try to print test page, then the printer appears offline. If I reboot the computer the test page is printed and printer appears ready. Unfortunately only until I try to print something, then printer starts appearing offline again. After reboot the file prints (of course only if it is something small). I try to print something new and the printer turns offline...
I tried adding the printer as local printer. The same problem persists.
Any suggestions?
