Printer Problem - or Spooler Problem
DeaconFrost
married to bearballet
7:25 PM
Philadelphia, PA
I have a user with a Windows 7 Pro SP1 x86 laptop, and an HP Color LaserJet 1600 connected locally by USB. HP doesn't offer drivers for this printer, so we've tried the built-in ones, and the updated ones from Windows Update.
The problem is, regardless of what is printing, the job sits in the queue, with a status of "printing". If I eventually try to delete the job, it takes several restarts before it is actually cleared out. We've swapped USB cables, reinstalled the printer twice, restarted the spooler service....no luck. The printer itself says it is ready. There are no errors, and nothing in the event logs.
Any suggestions...or has anyone come across this issue with this or a similar printer?
Intel Core i7-2600
Gigabyte GA-P67A-UD3P-B3
Nvidia GTX 470
Dell UltraSharp 2209WA
OCZ ModStream 700W
CoolerMaster HAF 912 Advanced
CoolerMaster Hyper 212 Plus
My GF's Dads HP LasetJet 4P with a laptop or a desktop running on Win 7 Home Premium x86 acts in the same way. Everything seems to be in order, sometimes will print, sometimes will just sit there like you describe. It's stumped me as there doesn't seem to be any problem.
Airbot 2.0
Zotac Geforce GTX 770
ASUS Xonar D2X
1920x1080@60hz
1 Samsung 250GB 840 Evo SSD
1 OCZ Vertex2 180GB SSD
Pioneer DVD Burner DVR-S18M
Corsair HX1000W
Cooler Master HAF 932
Logitech Wireless MK700
DL 15 Mbps UL 0.98 Mbps
None
Firefox Nightly
*Phone- LG Nexus 5
I had some problems with Win 7 x64 and my HP Photosmart printer. I wound up trying the Vista drivers and they worked alright. There has since been a Win 7 driver made for it, and everything now works except for the scanner. It still scans, but I can't control it from the PC, and it won't write the scanned file to an HD.
Maybe the Vista drivers will work for you DF. I hope so.
Mellon Labs (custom build)
AMD FX 8350 Vishera @ 4200
ASUS M5A97 R2.0
Acer 24", Acer 22"
3840 x 1080
1 x WD 1TB SATA Blue
1 x WD 1TB SATA Green
Corsair TX-750
CoolerMaster HAF 912+
Logitech G710+
Logitech G500s
Corsair VOID USB headphones.
Airbot 2.0
ASUS Xonar D2X
1920x1080@60hz
Corsair HX1000W
None
Firefox Nightly
*Phone- LG Nexus 5
I had a client with a HP and printer problems very similar to yours. I went to the HP site and they had a spooler fixer program that I ran and it worked fine. For some reason the print spooler gets confused.
give it a shot.
Rich
Toshiba Laptop Qosimo X870
Windows 7 Pro x64 SP1
Intel Core I7
Toshiba Qosmio
16 Gigs
NVIDIA GeForce GTX 670M
17.7" laptop
1600 x 900
256 Gig SanDisk SSD for C
256 Gig Intel SSD for D
50/25 FIOS
Vipre (all you can eat for 10 machines)
IE and FF
I have dos 6.22, wfwg 3.11, win98, 2000 and xp VHD's available for testing. MS's Virtual PC works great.
I have an old HP Photosmart 7960 which act the same way at times, usually after a period of non-use. When a print job gets hung, I pull the power plug for a bit and then plug it back and it prints. I have no fix for it, just use pull-plug-reinsert plug method.:confused:
Sometimes pulling the USB cable works too.
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
Are these the drivers you're using?
Yes, those are it. I'll look for the spooler fix program that richnrockville suggested, too.
Intel Core i7-2600
Nvidia GTX 470
OCZ ModStream 700W
If you find it, can you post it up? I'd like to have a go at it. Can't seem to find such a program.
Airbot 2.0
ASUS Xonar D2X
1920x1080@60hz
Corsair HX1000W
None
Firefox Nightly
*Phone- LG Nexus 5
Intel Core i7-2600
Nvidia GTX 470
OCZ ModStream 700W
Thanks. Doesn't seem to even work with the Laserjet 4P in particular. Works and has it on the list, but say it can't even connect to it on the first step. Oh well.
Airbot 2.0
ASUS Xonar D2X
1920x1080@60hz
Corsair HX1000W
None
Firefox Nightly
*Phone- LG Nexus 5
Thanks Deacon. I ran it and found no problems.:sarc:
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
It found problems for me on this system, and we rebooted, but the job still sat in the queue. I used the tool to kill the job, and then removed the drivers once again. After a reboot, I loaded the Universal driver, and now all seems to be fine. I never had much like with that driver when I worked for HP, but it did the trick this time.
Intel Core i7-2600
Nvidia GTX 470
OCZ ModStream 700W
Nice one. do you have a link for the universal driver? I'll give it a try.
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
I can get a link, but they may be different for the typ of printer...color, all-in-one, etc. If you go to HP's drivers page and search for the LaserJet 1600, and pick Windows 7 x86, it will be the only driver option for download.
*Actually, upon rechecking, the driver isn't the universal...just the generic color laserjet plug and play driver.
Intel Core i7-2600
Nvidia GTX 470
OCZ ModStream 700W
OK, thanks! I'll see what I can find.
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
