Problem need help
champ
Banned
5:00 PM
i build my computer installed all drivers n installed xp and it works perfectly fine when i try to install windows 7 this is the error i get my motherboard is gigbyte and it says it supports windows t on it and also amd is the cpu
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
Is there a setting in your Bios setup to enable ACPI ?
on motherboard
6 pata Ide HD's & 2 Sata HD's
All Generic Full Towers
Fast Cable InterNet
Linked via TeamViewer !
Do you know how to get into Bios setup upon system boot-up ?
Tapping DEL key a few times before windows loads .
Look for a section that enables ACPI
on motherboard
Fast Cable InterNet
i dont see it :( i really want windows 7 on this pc really want this to be solved fast
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
Might want to post system specs...
Home Grown
Windows 7 Ultimate (64)
i7-2600K
Asus P8P67-M Pro
G.SKILL Ripjaws X Series 8GB (2 x 4GB)
ATI 5750
On-Board
LG W2486L
1920X1080
Intel X-25M 80 Gig SSD | Intel X-25M 160 Gig SSD | WD Black 500MB - External eSata
Zalman ZM770-XT 770 Watts
Antec 180 mini
Cooler Master V8
15MB - Cable
Sissy OC - 4.6 @ 1.3175 24/7 | 18' Idle - 55' Load
I have the MB book for that board look under power Management in the BIOS setup for ACPI
on motherboard
Fast Cable InterNet
AMD Atlhon X250 (3ghz)
200 Hardrive
4gb ram
built in video card just watched last month n says supports windows 7 on it
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
ACPI Suspend tpye S3(STR) thts whts its on n the other one is S1(POS)
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
Try re-setting Bios with Load Fail-Safe Defaults.
I just bought that same CPU & MB from Newegg for a new build but have not built it yet. So I am sure I will work with win7 :D
on motherboard
Fast Cable InterNet
i need this pc ready by thursday with windows 7 in it plz help me out thanks
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
What version of win7 ? also is it 32 bit or 64 bit ? How are you trying to install ? Booting from DVD ? Not from within XP !!!
on motherboard
Fast Cable InterNet
its the orignal copy i have n bought n i m booting not from xp
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
If you just built this computer, why didn't you try to install win7 first ?
on motherboard
Fast Cable InterNet
my hardrive had xp plz doc can yah find solution
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
You need to re-set the Bios setup to Load fail-Safe Defaults or Load Optimizized Defaults
Safe & re-boot to the win7 dvd on new boot up
on motherboard
Fast Cable InterNet
i did load fail - safe default
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
You are still getting the ACPI error meessage when you try to install from the win7 DVD ?
on motherboard
Fast Cable InterNet
no when i boot the dvd it syasy loading windows file n th blue windoows 7 screen come n mouse on it nothing else no option or nothing
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
Yessss it workedddddddd
XP
AMD x64 (3.0ghz)
Gigbyte
4gb
