Straight to buisness: When I change power plans, let's say from "Power saver" to "Balanced" the changes does not take affect immediately. Any ideas?
Background:
I have just started using the Local Group Policy Editor (gpedit.msc), and these are the following changes I have made, and nothing else:
So my initial thoughts are that when I created a shortcut to <Control Panel\All Control Panel Items\Power Options>, the changes won't take affect immediately. Before I used to just right-click the power icon in the notification area, but as mentioned, I have hidden the notification area, so I can no longer do this.
I have also tried the following guide to create power plan shortcuts:
http://www.sevenforums.com/tutorials/21990-power-plan-create-shortcut-change-power-plan.html
That does not work either, so I'm stumped...only way to make the changes (for instance from "Power saver" to "Balanced") is to either reboot or log off-log on.
Background:
- "Hide the notification area"
- "Turn off all balloon notifications"
Windows 7 Ultimate 64 bit
- Windows 7 Ultimate 64 bit
