Problem with DVD drive after installation
Devices
Matt, are you able to get a screen shot for us?
Attached are screen shots of my devices with my drives circled in black.
I want to see what yours look like.
Windows 7 7600 1 X64
AMD PHENOM II X 550 PROCESSOR 3.1 ghz
ASUS M4A78-TE
Corsair 4 gig ddr 3
ati radeon 3300
ati hd
syncmaster 2033sw
1600X900 60 hz refresh
twin_seagates SATA's 1 TB & 500 Gig, hitachi_slimline 160 gig
antec_550 watt
cooler master GLite
stock_heat sink
20mbs up/ 1.5mbs down
favorite child "stewie"
favorite dog "brian"
Right managed to find a booklet concerning my motherboard its an ASUS M3A32-MVP Deluxe Series.
http://img23.imageshack.us/img23/8292/screenmgh.jpg
Thats a link to the screenie you asked for I hope I got that right, oh and I just want to say I really do appreciate all your help.
Alienware
Win7 Home Premium 64 Bit
AMD Phenom Quad Core 9650
4 gig's of DDR2
Sapphire Radeon 4870 1gig
Sony SDM-P234
1920x1200
Logitech G15
Microsoft DX8 Sidewinder
Upto 12MB (I get around 6-8)
Identified DVD connection
Hello Matt, we have identified your DVD/CD, good job getting the device manager screen shot.
Ok, we have identified your MOBO and your dvd optical storage device.
As we thought the drive is a SATA device so the settings need to be changed in the bios. Also it is possible that your MOBO's chipset drivers are out of date and you need to load the new chipset driver.
First thing first: We are going to update the Mother board, are you ready!:cool: First look at the screen shot I uploaded, what you are seeing is the ASSUS support site, ASSUS is the maker of your MOBO. The screen shot at the bootom of the picture is the chipset file specifically for your MOBO, I want you to follow : ASUSTeK Computer Inc.-Support-
Down load the update, its the last update on the bottom.
ASUS M4A78-TE
Corsair 4 gig ddr 3
ati radeon 3300
ati hd
syncmaster 2033sw
antec_550 watt
cooler master GLite
stock_heat sink
Chipset update
Matt after you download the chipset update you need to extract it to a folder or location where you know where the set up file is. After that you will need to run the set up file. The set up file will run automatically. After it has installed the new updates and drivers, reboot the system and tell us what happened.
ASUS M4A78-TE
Corsair 4 gig ddr 3
ati radeon 3300
ati hd
syncmaster 2033sw
antec_550 watt
cooler master GLite
stock_heat sink
SALUTE
Salute! Take a rep Matt. Good job!
ASUS M4A78-TE
Corsair 4 gig ddr 3
ati radeon 3300
ati hd
syncmaster 2033sw
antec_550 watt
cooler master GLite
stock_heat sink
Been out all day today so not had a chance to try this until now, I downloaded the file and updated the chipset but the same problem persists with the DVD drive.
Alienware
4 gig's of DDR2
Sony SDM-P234
1920x1200
Logitech G15
Do you have a 4 gig flash stick?
ASUS M4A78-TE
Corsair 4 gig ddr 3
ati radeon 3300
ati hd
syncmaster 2033sw
antec_550 watt
cooler master GLite
stock_heat sink
I notice the early comment to update DVD drive firmware was skipped over. Reason?
Here is the link to latest firmware, click Drivers and Software tab on product support page: LG Product Support for GSA-H55N
File attached below:
Follow the ReadMe in the zip file.
Greg, Matt performed the firmaware update, he describes doing that on the first page.
ASUS M4A78-TE
Corsair 4 gig ddr 3
ati radeon 3300
ati hd
syncmaster 2033sw
antec_550 watt
cooler master GLite
stock_heat sink
I did not skip over it perhaps I was not clear previously, after I had deleted the driver and let windows find the drive after a fresh boot to no avail at that point I then tried installing the drive from the LG website still no change with the problem.
Alienware
4 gig's of DDR2
Sony SDM-P234
1920x1200
Logitech G15
Let me save everyone troubles with this.
The lens in the drive is either dirty or defective. Open it up, put a little rubbing alcohol on a q-tip and clean it gently. Use a dry q-tip to dry it.
If that fails, toss the drive in the garbage and purchase a new one.
I didn't read every last word in here, but a firmware update has a slight chance of fixing too. Try that also before tossing.
self built
7600.20510 x86
P4 550 3.4 GHz HT running at 3.5 GHz
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
OCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHz
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
If the drive is faulty I have no problem replacing it a new DVD drive is not exactly expensive, however it seems strange that this problem reared its head immediately after I installed my fresh Win7 install.
The one other thing about installing a new DVD drive is I have never done that before, memory yes, gfx cards too but never a DVD drive but I suppose it cannot be that difficult.
Alienware
4 gig's of DDR2
Sony SDM-P234
1920x1200
Logitech G15
I'd really have to say it's coincidence. I've fixed many drives with your no DVD reading problem like this. And tossed many unfixable ones too.
It's very simple to attach a new drive. Take the broken one to the store and they will help you find a replacement of the same type. Install it back in the case with screws, attach two cables and done. There may be a jumper needing to be set. You can ask them about that at the store. They will see your original drive.
If you want, keep the original broken one. If the new one you buy fails in your system (extremely unlikely), return it to the store as you don't need it and I've given you bad advice.
I really don't think this is bad advice. :D
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Sorry thought you said driver and not firmware.
If it let you install Win7 then it may have crapped out. torrentg's suggestion to try cleaning the lens is a good last shot, then find a quality brand replacement at store $50-90 vs. buy.com or newegg $25-40.
Optical drives are becoming less important as flash stick prices come down. I have my 7 install files on primary formatted flash stick in a folder with all other apps/tools - when I wanna install I just move the files into the root and boot from it.
