Problem with internet speed on one of two computers using same router.
kmleuze
1:01 PM
Hi, I have two computers (one a wireless laptop, one a wired desktop), both are running Windows 7. The wired desktop has a download speed of 10 Mbps while the laptop has speed of 30 Mbps. (Both were connecting at the same, fast speed before.
I tried replacing the cable that connects the computer with the router, but that is not the problem. A friend brought his computer over and it also ran at 30 bps.
It has been like this for about 3 weeks, although for one day, the speed was back up to around 30 Mbps, and then dropped back down, and it has not changed since then.
Windows 7, 32bitInspiron 530S4 GB RAM,
Windows 7, 32bit
Inspiron 530S
4 GB RAM,
250 GB
Charter Cable "F Secure"
Depending on your router, you can set your MAC ID to receive priority bandwidth. I do it so that my neighbor doesn't suck away the bandwidth when I'm watching Hulu or such. Worked great until my g/f told the neighbor what I'd done thinking she was talking about a different neighbor.
Microsoft Windows 10 Home Build 15036Intel(R) Core(TM) i7-860 @ 2.80GHz4.00 GBNVIDIA GeForce GTX 750
iBuyPower NZXT
Gigabyte Technology Co., Ltd. P55-UD3L
4.00 GB
(1) Line 6 UX2 (2) Realtek High Definition Audio
23" acer
(1) WDC WD5000AAKS-00D2B0 ATA Device (2) Seagate FreeAgent Go 250G USB Device
Corsair H75 liquid cooler (Very easy to install, actually)
60M cable modem-->Linksys E1200-->1Gbps net card
This is probably the longest I've ever had a Windows machine run without having to restore it to scratch. I'm used to restoring to "factory" about every 2 yrs. I've run with Win7 since new in 2009 and only recently (Nov, '14) restored to clean up the machine from all my 'xperimenting. LOL!! I may never need another machine.
Upgraded to 10 when it was still free, then installed 2017 update.
Hi kmleuze,
Welcome to the Seven forums.
Please check the desktop only with the laptop disconnected from the network and then monitor the speed.
Make sure there are no other system connected to the network so you can isolate the issue. Also, let us know the Ethernet card installed on the system.
You can also boot the system to safe mode with networking to isolate this issue:
http://www.sevenforums.com/tutorials/69585-safe-mode.html
Hope it helps.
Winndows 7 32 bit
Winndows 7 32 bit
