Windows 7 64-bit Professional
Geforce 9800GTX, 266.58 nvidia drivers
Asus VW222U 22inch LCD
Ok, so randomly my monitor just disconnects. Basically I hear the hardware disconnect sound (just like removing a usb key) and my monitor goes black and it says No signal (same as what it would say if the monitor was on but computer was off). Restarting the monitor doesn't fix it, nor does unplugging and replugging it. To fix it, I usually click on the sleep button on my computer and let it go to sleep. Then I turn the monitor off and at the same time I turn the monitor back on and wake the computer up. This usually takes 3 or 4 goes, but it gets my monitor working again.
Sometimes when sleeping/waking several times doesn't fix it, I have to reboot. And even then when the computer is booting up it doesn't always fix the monitor and the monitor still says No signal. So I have to reboot several times until the monitor finally gets a signal. (Does this say anything about what could be causing it? I mean, the gfx card isn't yet running before windows loads, is it? Which means it's not the gfx card at fault? Or is it?) Also, sometimes when it's having trouble getting signal while booting up: it gives the message out of range.
I've had this problem for ages now, on multiple formats and driver versions, so I'm guessing it's not software related. It happens usually when I'm launching or exiting out of a full sceen game or sometimes even just randomly when I'm doing nothing just browsing web.
I'm guessing faulty monitor?
- Windows 7 64-bit Professional
