Problem with MsConfig Service called "Power" and also my audio
Marcologue
10:30 PM
I was having huge lagging and crashing problems until I found out it was the Microsoft Service called "Power" in MsConfig that was the culprit. When I disable it, it fixes my problems, but now I don't have audio anymore.
Can anybody help?
Windows 7 - 64 bits
Windows 7 - 64 bits
Power manages your power configuration. Check the Power settings and see if any can be changed?
Lenovo IdeaCenter 450
Windows 10 Pro X64
Intel Integrated HD Graphics
HP 22" LCD
250GB Samsung EVO SATA-3 SSD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
PLDS DVD-RW DH16AERSH
What is Power setting?
Windows 7 - 64 bits
Windows 7 - 64 bits
Control Panel, Power Settings. Maybe try a different power scheme or change some settings.
Windows 10 Pro X64
HP 22" LCD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
Well that worked thanks! Never though of simply doing that... I had to reactivate the Power Service to access the Power Options cause it didn't want to open. After accessing the Power Options, I went to Create a Power Plan and chose High Performance. I guess I might have played in the advance setting of the other default options and screwed something up!
Windows 7 - 64 bits
Windows 7 - 64 bits
Good going, glad it's fixed.
Windows 10 Pro X64
HP 22" LCD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
