Problem with Radeon 4890 with Sony Bravia HDTV
RiGu
1:47 PM
Hello,
The problem is that for some reason I cannot get a pixel perfect screen to the Sony Bravia Full HD LCD TV with the Radeon 4890. There are always black borders around the screen.
Have the Catalyst 9.11 Suite for Windows 7 (64 bit) installed.
With a Nvidia 8800gt there is no need for any kind of settings, the picture is pixel perfect HD 1080p straight away.
Any idea how to get the resolution / settings correct?
Windows 7 Ultimate 64bit
DO you have HDMI to HDMI connected, and fiber optic cable from the sound card to your home theater receive
Obviously this us the best way but could you tell me what connections are on your TV and computer?
Windows 7 Pro & Vista Home PremiumAthlon 64 3800+ (Orleans) 2.40GHz2GB DDR2 RAM DIMMNVIDIA GeForce 8500 GT 512 MB memory HDMI out
Cheap $399.00 E-Machine
Winfast
2GB DDR2 RAM DIMM
creative X-Fi Exteme 7..1 channel
Acer V223W 22" widescreen DVI
WDC WD5 500GB
WDC WD25 250GB
OCZ 550 watt
Gateway
2 fans
Sony Vaio
18MB/s down - .72MB /s up
Hello,
If you don't want to deal with the black boarders, you need to use the PC input on the TV and not the HDMI input. If you need to use an adaptor it should be on the PC then use standard HD-15 TO HD-15 cable from the PC to the TV's PC input.
The black border can be adjusted using the custom resolution setting but there are other problems that go along with that.
Sony insists that you need to use the PC input on the TV in order to have resolution be correct. I just set mine up last week and went through the same routine, resolution not correct when using the HDMI input on the TV.
Everything works perfectly including full surround from the PC through my Sony BD player when playing a movie on the PC. I didn't even need to use any type of SPDIF pass through. I just went from my sound card with the single green wire to the sound port next to the PC input on the TV.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
if ure tv doesnt have an option too automaticly fit the picture to right size .
open up ccc /Graphics drop down box/desktop display/right click over the moniter in bottom left hand corner/configure moniter/scaling options / then move the slider till the picture fills the screen
7 RTM 64bitAMD Phenom 965 B3Corsair 4GB (2x2GB) DDR2 800MHz/PC2-6400 XMS2...PowerColour HD 5770 CF 16x-16x
7 RTM 64bit
AMD Phenom 965 B3
ASUS M3A79-T DELUXE
Corsair 4GB (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory Kit CL5
32"
Hitachi
1tb 7200rpm
Be Quiet Straight Power 650wat
Asus TA-M series
CoolIT Eco ALC Water Cooling System
Microsoft wireless Keyboard
Microsoft wireless mouse
