Problem with right click on programs pinned to taskbar.
Spr07
9:29 PM
Hello.
I hope I'm in the good section for my post.
When I right click on Windows Media Player on the taskbar, the recent files and task lists appears, but don't work : when I click on a file or a task, nothing happen :(.
However, it worked at the beginning (just after Windows installation), and it still work for other programs.
I tried a system restore, and the problem persist.
I'm on Seven Beta 1 (Build 7000).
Could you help me? Thanks.
Packard Bell
AMD Turion 64 x2
3 GB
ATI Mobility Radeon HD 2400
1280*800
2 MB
Dell XPS420
Creative SB X-Fi audio
HP w2207 + HPvs15
1680x1050 + 1024x768
2-WD5000AAKS-500 GB
WD5000AAV-500 GB external
Microsoft Comfort Curve
MX Revolution
Experience Index=5.5
I followed your advice and tried a System File Check.
It found some errors and repaired them, but the problem persists. :(
Packard Bell
AMD Turion 64 x2
3 GB
1280*800
2 MB
Have you tried to unpin Windows Media Player from the taskbar and then pin it back again?
ENIAC
Windows 7 RC 7100 32bit/64bit
Intel Core2Duo E4500 2.20 GHz
ASUS P5LD2-X/1333
2x1GB Kinsgston DDR2 800MHz
Nvidia 8500GT
Onboard High Definition Audio Device
Sony Bravia 42"
LINKW 2222
Standard Intel
Some cheap one
Microsoft Intellimouse something
24MBps ADSL
I can pin and unpin Media Player, but I've still my problem (even after restart).
I've the same "bug" with Live Messenger (2009), which is not pinned to the taskbar...
I don't know what to do...
Packard Bell
AMD Turion 64 x2
3 GB
1280*800
2 MB
I found the correct word for my problem : there are the Jump List of Media Player and Messenger which not work...
Any idea please?
Packard Bell
AMD Turion 64 x2
3 GB
1280*800
2 MB
Airbot 2.0
Zotac Geforce GTX 770
ASUS Xonar D2X
1920x1080@60hz
1 Samsung 250GB 840 Evo SSD
1 OCZ Vertex2 180GB SSD
Pioneer DVD Burner DVR-S18M
Corsair HX1000W
Cooler Master HAF 932
Logitech Wireless MK700
DL 15 Mbps UL 0.98 Mbps
None
Firefox Nightly
*Phone- LG Nexus 5
Thanks.
I will try...
Doesn't work.
I was this problem on Build 6956 and the upgrade to Build 7000 didn't fix that.
I already sent feedbacks to Microsoft, but actually I can't use Jump Lists of Media Player and Messenger. Files are here but links don't work :cry:...
I decided to reinstall cleanly Windows and I recovered Media Player Jump List.
I found why I had this problem : it's an incompatibility between a-Squared Anti-malware and Windows Seven.
My problem is now fixed :)
Packard Bell
AMD Turion 64 x2
3 GB
1280*800
2 MB
I have the same problem with jump list with media player and messenger.
I have tried a repair install same problem?
Any ideas as it is driving me mad. Jump lists work with internet explorer and windows explorer.
I found why Jump List didn't work: because I installed programs which "deactivate" Jump Lists (except Internet Explorer and Windows Explorer).
Did you installed A-Squared or Systran Translator (program, not gadget) on your computer? If yes uninstall it, or restore your system to a date before installation. If no, what program?
Packard Bell
AMD Turion 64 x2
3 GB
1280*800
2 MB
I do not have any of those programs on my system. I have itunes, avast.
I really do not know how to get it to work.
Avast is not responsible, but I don't installed iTunes... I don't know :confused:
Packard Bell
AMD Turion 64 x2
3 GB
1280*800
2 MB
