You should upgrade or use an
alternative browser .
Problem with settings after using Tv-out
Hello,
I used TV-out before 2 days with this setting "Extend These Dislpays"
Everything was fine.
Then back to the setting "Show desktop only on 1"
Now every time after reboot the setting "Extend These Dislpays" is active again, and each time I return it to the "Extend These Dislpays", but I'm fed up already. Not that the problem is any important, but when it is "Extend These Dislpays" I lose my cursor in the second display, which does not exist now
I have nVidia FX5500
If anyone has any ideas to speak. Thanks in advance
Computer Manufacturer/Model Number AMD OS 7 CPU Athlon64 3700+ SAN DIEGO Motherboard Asus A8V Memory 2GB Kingston Graphics Card(s) nVidia FX5500 Sound Card 8 chanals Monitor(s) Displays 19" Screen Resolution 1280x1024 Hard Drives 40GB+120GB PSU FORTRON ATX-350PNF Cooling Evercool K802-715CA Heatsink Internet Speed LAN 10MB/s
Old School
You might have better luck posting this question on nvnews.net, where the Nvidia gurus hang out.
Computer Manufacturer/Model Number DIY OS W7x64 Pro, SuSe 12.1/** W7 x64 Pro, XP MCE CPU Phenom II 1090T w/Noctua NH-D14 /**4400+ X2 w/CM Hyper TX 3 Motherboard ASRock 890FX Deluxe 4/**A8N-SLI Memory 2 x 2GB Patriot PGS34g1600LLKA/**4x1GB Corsair VS Graphics Card(s) EVGA GTX460 SC/**EVGA 8800GTS Sound Card Asus Xonar D2X/**Xonar D1 Monitor(s) Displays Acer X233H, Dell E152FPc /**LG M237-WD Screen Resolution 1920x1080 & 1024x768/**1980x1080 Hard Drives WDC 2TB, 1.5TB, 1TB, 500GB,Seagate 500GB , Maxtor 80GB /**500GB Seagate & WDC 1TB Black PSU CM RS600 w/ APC BX1000G/**Antec 500 TP w/ APC BX1000 Case HAF922/**Antec 1040IIB Cooling 3x200mm, 1x140 and 1x120mm/**5x80mm fans Keyboard Logitech Media USB/**Saitek Eclipse Mouse Cordless Trackman Wheel/**Ditto Internet Speed 3.3Mbps Other Info SB 560 5.1 w/ Sennheiser RS140/**Creative T20 speakers, Dvico FusionHDTV7 Gold RT, Cisco E3000, HP 5510V AIO, Linksys E3000, Belkin F5U237 hub and **F5D8055 adapter
(** = 2nd rig)
