problem with sound card
luciferspulse
7:05 PM
hi to all
i recently updated my pc to
asus p6x58d premium
intel i7 950
corsair 2x3 gb ram triple channel 2000 mhz
power 900 watt acbel
gtx 295 vga
3 sound cards:
1.tc electronic konnekt 8 external sound card connect with pc via firewire(i must use it for music making)
2.creative xfi xtreme audio(for game)
3.realtek hd audio (original mb sound)
but in this system after installing my win7 64bit and installing tc.electronic driver the software control panel says no device is found but the blue light is on and its wierd!(its an indicator on my sound card and it lit when the device connects to a pc which has been installed its driver)
device manager says the 1394 port works fine but sound tab on control panel doesnt recognize my tc electronic sound device
but 2 others are visible and are ok.
i disabled realtek at bios setting but didnt work
i disabled creative xfi at device manager but didnt work either.
is this problem for using 3 sound device at the same time?
my 1394 port seems to be ok and my konnekt 8 too because it works fine on my laptop
please help me
windows 7
amd phenom II 955 black edition
dfi lanparty m2R
4 gb ddr 2 crucial ballistix 1066
nvidia gtx 295
creative xfi xtreme audio+tc electronics konnekt 8
samsung 206 bw
wd 500 gb
acbel 900 w
green tuniq 2
green case original
Probably driver. If green light is on that means the card is physically connected correctly. If no entry in control panel for card, you need a compatible driver
custom build
WinXP / Win 7 / Win 8.1 64bit Dual Boot
i7-4770K
Asus Z87-A
16 gb G.Skill Ripjaws
on board 4600
On Board Soundmax HD
Dell 19" Flat Panel
1280x1024
Samsung 840 Pro 512gb SSD
WD1001 Caviar Win 7 Boot
WD500 Caviar Win XP Boot
2xWD500 Caviar (Raid 0)
WD750 Caviar (Backup)
Aerocool StrikeX 800w x2
Aerocool Strike X
Air
Microsoft Wireless
Microsoft Wireless
Cable
Asus 12x Blu-ray writer
i think its about driver too but question is why device works fine on my laptop with the same driver?
windows 7
dfi lanparty m2R
nvidia gtx 295
samsung 206 bw
wd 500 gb
acbel 900 w
green tuniq 2
green case original
any answers?
i got the correct answer last time in this forum and that problem was about my tc electronic too which caused bsod during running games and it solved here,i hoped this problem solve here too.
windows 7
dfi lanparty m2R
nvidia gtx 295
samsung 206 bw
wd 500 gb
acbel 900 w
green tuniq 2
green case original
laptops are built differently than desktops. Their parts are usually more condensed and they can act slightly differently, being geared to be wireless.
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Samsung SSD 840 PRO Series
Seasonic S12II-380Bronze
Lian Li
Fan, Passive
Logitech K120
Microsoft Touch Mouse
Eset Endpoint
Internet Explorer, Chrome
