problem with sound
dadli88
1:43 PM
:rolleyes:My frend install on my computer windows 7 and I have problem with sound, In right bottom panel, on the speaker icon is red cross. Please tell me what make? how to on sound in computer?
Windows 7 Home Premium 32bit
Most likely you are missing the audio driver.
If you give the make and model of the computer, someone here may be able to find a updated driver that will work properly for you.
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
G.skill Ripjaw 16gigs @ 1866
Nvidia gtx580 (evga)
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
The red cross over the speaker icon means that the sound is off. Double Click on the speaker and the volume control will open up. You will probably see another speaker with a red cross on it. Just click it one time and your sound should work. Let us if we helped. Thanks,
Intel Core i3-2120 3.30Ghz
Kingston 4 GB DDR3 1333 mhz
AMD Radeon HD6670
Asus VE228
1440 X 900
Corsair CX600M == 600 Watt
Three 120 mm Fans
Microsoft Natural 4000
Microsoft Custom Optical 3000
when mouse is over on the speaker icon, i see this message: "No Audio Output device is installed" and i think this is the problem, but i dont know how to resolve it, please tell me, how to install Output device?
It might be helpful to right click the speaker icon, select Playback Devices and see if your speakers are there with a green check.
The missing driver mentioned may be a factor since having a speaker muted shows a red circle with a line... Windows will normally install some type of sound driver.
Other things you might check is whether you have an HDMI output selected for sound output.
Homebuilt
Windows 7 x64
i7-2600K
Asus P8Z77-v Pro
8 G
GTX 480
Onboard
LG W2753V
Crucial M4 128 G SSD
On right click the speaker icon, if select Playback Devices, I see: "no audio devicess are installed", but with program "everest", when I click on "sound video and game controllers" I see submenu: "High definition audio device" and see this properties:
Driver description: High definition audio device
Driver Version: 6.1.7600.16385
and etc
So I dont understoood, what happens? the audio driver is already installed or not? if not, what is this: "High definition audio device" in my computer? and if yes, why is this message: "no audio devicess are installed" in Playback Devices?
Please help me
As I said in my first post, if you can provide more basic information about the make and model of the computer we can probably track down the 'audio device driver' you need.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
Maguscreed
Ok, just tell me, concret what information give you on my computer?
If it's a computer you purchased prebuilt it should have a sticker on it somewhere with a model number.
usually on the bottom if laptop or on the back panel somewhere if desktop.
Some older hp's have the model number right on the front of the case.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
aaa.. I dont know when must see computer model, I can tell you what audio adapter have I, this is:
VIA VT1705 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
Maguscreed
Thanks very much, problem is resolved :)
