Solved Problem with startup, applications do not load
beauedwards
10:52 PM
Hello there! I appear to be having a problem with applications not loading when I start the PC. It happens every now and then, and I am forced to reboot until I can eventually load the program. When I check the program in task manager, it appears to only load about 108K-124K within memory, then stops. When this happens, I can no longer run any program. I am at my wits end! Many thanks in advance for any help I may receive.
AMD Athlon II X2 215
Compaq-Presario WC870AA-ABU
2.0 GB
ATI Radeon HD 3600
Hello Beauedwards, Welcome to SF!
Can you give us a bit more to go on? What program? When it "stops"... what happens exactly? Does your whole pc freeze? Do you get a BSOD (Blue Screen of Death... which means your PC doesn't like you any more and it quits on you with a (most of the time) blue screen)
How quickly after booting do you try this program? How up-to-date are you with W7 updates?
W7 64b on a 2G machine is sure to test your patience anyway but let's see what is really happening...
custom build
Windows 7 64b Ultimate
I7-2600 3.40GHz - testing various OC levels..
ASUS Sabretooth
2x 4Gb DDR3/1333
GTX570 - testing OC levels
motherboard 7.1 DIG.
2x Ilyama 24" E2409HDS-B1 2ms/DVI
120 GB Intel Elmcrest SSD
1 TB SATAII 7200RPM/32MB
External 2TB USB3
Corsair Pro HX850W
Coolermaster Hyper V8
Logitech G110
Logitech G700
25Mb
CPU: 7,7 RAM: 7,7 GTX: 7,9 GTX 3D : 7,9 SSD 7,6
Overall 7,6 ...... now to speed up the SSD... ;)
Also use a Dell XPS M1710 on Vista 32b
Asus LT on Vista 32
3 older machines still doing fine on Linux/ubuntu but not used much anymore...
I believe the problem has been fixed now. Apparently, my graphics card software had overclocked my CPU and GPU. When the software was updated, it reverted to default clock speeds, and since then, no problems. Thank you for the assistance!
2.0 GB
ATI Radeon HD 3600
My pleasure, glad you're ok now!:D
custom build
ASUS Sabretooth
2x 4Gb DDR3/1333
External 2TB USB3
Corsair Pro HX850W
Logitech G110
Logitech G700
25Mb
Asus LT on Vista 32
