Problem with the connection
chkoupi
6:32 AM
south africa
hi all :):D
i have a problem with my VPN/access distance connection that's when i connect into it log in normally without problem but the network icon keep showing me that there is a problem what's it ???? i don't know
this is the snapshot
see here :geek:
http://img686.imageshack.us/img686/1686/capturelj.png
help meeee :cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry:
and another thing when i create a new connection and when it's says 'test ur connection' it fails but when i connect manually no problem but the icon shows that there is a problem :cry::cry::cry::cry::cry::cry::cry::cry::cry:
biostar
windows 7 Professional build 7600
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
help guys ????????
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
help ?????????????
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
I cannot read what is in your image. What is your VPN, do u need to first access the internet then "dial" into your VPN? or is your "VPN" the internet access?
Lenovo ThinkPad T60
Windows 7 Ultimate 64Bit
GenuineIntel Intel(R) Core(TM) DuoCore T2400 @ 1.83GHz
Intel(R) 82801G (ICH7 Family)
2.00 GB
Mobile Intel(R) 945 Express Chipset
ThinkPad Display
1400x1050
100Gb SATA
Standard Keyboard
HID-compliant Mouse
Cable Broadband - 54Mbps
Intel(R) PRO/1000 PL Network Connection
11a/b/g Wireless LAN Mini PCI Express Adapter
yes but i haven't problems it should show to connection the 1st the nework "no internet access "
and the 2nd the 'FAWRI' the name of the ISP "internet access" but now i can't see it that's means there is a problem
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
I trust that there is a problem. But i'm having trouble understanding your situation.
Are you connected wireless or cable? nevermind i figured you may have both.
I'm guessing you have one connections which has internet access, and a second which does not. correct?
Lenovo ThinkPad T60
2.00 GB
ThinkPad Display
1400x1050
100Gb SATA
Standard Keyboard
HID-compliant Mouse
here's the 2nd photo
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
cable connection
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
i'm soory my windows by FRENCH
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
Ok so it seems you could have an issue with connecting to your ISP.
Are you using the ISP's DHCP to obtain an IP (auto detect settings)? If so, can you give details of "ipconfig /all"?
Lenovo ThinkPad T60
2.00 GB
ThinkPad Display
1400x1050
100Gb SATA
Standard Keyboard
HID-compliant Mouse
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
From that i would have guested you are missing a DNS Suffix entry, your default gateway is wrong, these should be provided from your ISP. Are you sure you have not manually input any settings?
Try disabling ipv6.
Lenovo ThinkPad T60
2.00 GB
ThinkPad Display
1400x1050
100Gb SATA
Standard Keyboard
HID-compliant Mouse
i have set a setting in my network cause i'm using a HUAWEI SMART AX MA880 that's why you should set ur ipv4 by these setting 192.168.1.3 etc .....
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
If you manually put in your IPs then you need to manually put in the correct DNS IP, Default Gateway, etc. for you to connect to the net you need to get onto your ISP's network. Incorrectly putting in details or missing details you won't be able to connect. For the Huawei i guess there are other settings (for softrware) which you need to check as well. Speak to your ISP.
Lenovo ThinkPad T60
2.00 GB
ThinkPad Display
1400x1050
100Gb SATA
Standard Keyboard
HID-compliant Mouse
hey
biostar
intel dual cpu 2.00
bios star
2gb
nvidia 9400 gt 1gb
realtek 64
generic PNP monitor
1600*1400
150 gb
512kb
