Problem with ? turning into / in XP Mode.
CaveSpringPark
2:41 PM
Odd problem here. Our receipt printer only works in XP Mode (32 bit drivers only) so we run our POS software in XP Mode. Everything works great except that when you swipe a credit card (USB magnetic card reader that acts as a keyboard) the numbers end with a / instead of a ?
On the Win7 side the data is inputted correctly.
I can't figure out what changes between Win7 and XP mode.
If I hold shift down while swiping the card it ends with the ?, but that of course messes up the rest of the characters.
Any idea?
Thanks!
Windows 7 Pro 64bit
I was able to solve this problem by downloading
Microsoft Keyboard Layout Creator 1.4 and mapping the /? key to ??.
Now the only way to make a / is the num pad, but that beats inputting all those credit cards manually.
Thanks for looking
Windows 7 Pro 64bit
Just one suggestion - what happens if you map ? -> / and also map / -> ? thus swapping the shifted and unshifted key mapping - if this works it will give you a usable system
My Computers
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
Then you just turn the key upside down ;)
Good suggestion, BarMan.
Pugh Technologies
W7 Professional x64
AMD Athlon II X3 445 Rana 3.10 GHz
MSI 870A-G54
PNY XLR DDR3 1600 4x2GB
NVIDIA GeForce GTS 450 (fermi) 1GB GDDR5
Realtek ALC892 onboard
ASUS VE205t, Viewsonic VX2035WM
1600x900, 1600x1050
977GB Hitachi Hitachi HDS721010CLA332
244GB Western Digital WDC WD2500AAJS-65B4A0
488GB Western Digital WDC WD5000AAJS-00A8B0
488GB Western Digital WDC WD5000AAKS-00UU3A0
Antec EarthWatts EA650 650W
ThermalTake Armor A90 Mid Tower
3x 120mm in, 1x 120mm & 200mm out, self built hydro-cooler
Logitec 55
Razer Deathadder
20 Mbps D/L, 9 Mbps U/L
Excellent suggestion BarMan! Works perfect.
Haha I considered, but stopped short of flipping the key LiquidSnak.
Windows 7 Pro 64bit
