Problem with wireless network connection
Lukeluke
11:42 PM
i have a problem connecting to my home router. When i start W7 (64bit), after a bit, the small icon that shows internet connection status shows no connection. Usualy, when it is working, when i left-click on it, i can see the list of wireless connections avaiable. But now, when i left-click on it, no list is shown and no connection to my router is done, even if i can connect to it with other devices (for example my android phone).
Now i am connected to internet after starting W7 in safe mode, so i suppose that some program i installed is not working properly. But i have really no idea of what program is doing this or how to find it!
What can i do to fix this?!?
Samsung
Windows 7 Home 64bit
i7
8 GB
NVIDIA
You can use Autoruns to help you find the program that is causing the problem.
You can disable groups of start up programs or just one at a time until you figure out which one is causing the problem by process of elimination.
Autoruns for Windows
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
ACER ASPIRE 5742G
Acer Aspire 5742G
4,00 GB
WDC WD5000BEVT-22ZAT0
If this issue started occurring after doing some recent software changes on your computer, then I would suggest you to restore your system back to a date when it was working fine. System Restore will affect Windows system files, programs, and registry settings only.
For System Restore steps, you can refer to the URL mentioned: http://windows.microsoft.com/en-US/windows7/products/features/system-restore
Share your comments if it solved your problem.
Windows 7 Enterprise x64
