Solved Problems using dual screens with a laptop and monitor...
topcat9h
3:48 AM
Hey. Firstly, apologies if this is a noob question but any guidance will be helpful.
Basically, i have a LCD monitor connected through HDMI to my laptop and both screens are working at the moment as duplicates.
What i am after is the screens to coincide and for me to be able to drag a window from my laptop to monitor, or vice versa.
When i have the 'extend desktop on 1 and 2' setting selected my laptop works as normal but the monitor screen only shows the wallpaper of my laptop and nothing else.
Is there anything i can do from here to be able to use both screens together or am i simply stabbing in the dark?
Thanks in advance,
Topcat9H.
Windows 7 home premium 64 bit
So what happens if you drag a window from one screen to the other or press
(Windows key + shift + >) or (Windows key + shift + <) ?
Windows 10 Education 64 bitAMD Phenom II X4 980 Black Edition Deneb 3.7GHz8GB 4GBx2 Kingston PC10600 DDR3 1333 MemoryZotac NVIDIA Geforce GT640 2 Gig DDR3 PCIe
Home Built
Thermaltake TR 620
Stock heatsink and fan
Logitech Wireless K350 Wave
80 Mbps Down 30 Mbps Up
Windows Defender
Internet Explorer 11
Nothing, it just acts as a single screen on the laptop and the window moves around the screen like normal. The monitor only shows the wallpaper and that is what makes me curious as it seems to connect just not work?
Thanks,
Home Built
Thermaltake TR 620
Windows Defender
How embarrassing... I was dragging the window the wrong way as my monitor is on the left. Sorted now though!
Thanks very much for your effort.
I was thinking that might be the case, thats why I mentioned the Windows key + shift key + > key keyboard shortcut for moving a window from one monitor to the other. Only problem is I got it wrong, its Windows key + shift key + arrow key. ops, :o If you go back to that screen in the tutorial where it shows your two monitors, you can reverse them just by dragging one to the other side so they match how you actually have them positioned. It may make things easier.
Home Built
Thermaltake TR 620
Windows Defender
Haha i was curious about the shift keys and why it wouldn't work!
It's sorted now and i'm messing around with the monitor drag setup so i can have the monitor attached to a wall above my laptop for films and stuff, it's a great feature.
Many thanks, Topcat9H
:thumbsup:
Home Built
Thermaltake TR 620
Windows Defender
