Questions to use for help with Installation Issues
Dave76
Endeavor to Persevere
3:18 PM
Wanderer
Questions to answer for help with Installation Issues
Welcome to Seven Forums.
In order to help resolve your installation issues, we would like to get some initial information.
Your answers will help us to eliminate some of the possible causes, and focus on the solution.
First, we will need your system specs, if you haven’t filled them in, please do so.
If you need help finding your computer specifications try SIW - System Information for Windows, this will give you all the information required.
Where do they go? Click ‘User CP’ on the top tool bar of any Seven Forums page. On the left side under Your Control Panel, click Edit System Spec.
It is Highly Recommended to make a Backup Image of your entire hard disk before any Operating System installation.
Seven Forums tutorial for the Windows 7 Backup and restore program:
There are more Seven Forums Backup and Restore tutorials:
Other Free Backup and Restore programs can be found at this Seven Forums thread:
Second, general information about your installation.
Current Operating System, pre-install
• Do you have a single OS on your computer, are you planning on multi-booting with this installation?​
• Are you multi-booting now?​
Current Hardware
• How many internal hard drives (HD) are connected to your system?​
• Are they IDE or SATA?​
• How many DVD drives are connected to your system?​
• Are they IDE or SATA Drives?​
• Any external HDs used?​
• Are they connected by USB or eSATA?​
• Check Disk Management for any HDs listed with a yellow triangle and explanation point?​
• Is this a New Clean HD?​
• Have you pre-formatted the HD?​
Windows 7 installation details
• Which build number and version of Win7 are you installing?​
• Are you installing a 32 bit (x86) or 64 bit (x64) OS?​
• Where did you get the ISO file from?​
The procedure and speed of burning the ISO to DVD has been the most frequent cause of installation failure
• How did you burn the DVD? Briefly describe the steps you used.​
• Which ISO burning software did you use?​
• At what burning speed and with Verify checked?​
• A slow burn speed, lowest setting (example x4 speed), will ensure an error free burn.​
Here is a very good tutorial on burning an ISO:​
Due to burning DVD failure to install incidents these alternative methods are suggested
There are two non DVD methods for installing Win7:​
• Installation using a USB key (Memory stick, Flash Memory) it’s easy and fast to setup using this tutorial:​
• Installation from another partition or hard disk, try this tutorial:​
• This partition or hard disk method is designed for advanced users:​
Other
• Any Over Clocking of the RAM, CPU or GPU?​
Suggestions
• Remove everything not essential to loading Win7, from the system. No printers, gamepads, second monitors, scanners, external devices, flash drives etc., keep only the monitor, keyboard and mouse.​
• A standard VGA cable connection between Video card & Monitor is sometimes required for a Win7 installation.​
Thanks to DocBrown for the original list.
   Tip
You can cut and paste the questions below on your New Thread to easily give the answers:
Current Hardware
Installation Media
• Using a USB memory key?​
• From another partition or hard disk?​
• From a DVD?​
Other
Thank you for providing the information we need to help resolve your installation issues.
76~2.0
Intel Core i5-3570K 4.6GHz
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
Too many to list.
XP, Seven, 2008R2
AMD, Intel, VIA
Various
Corsair, Kingston, etc.
ATI, NVIDIA
Samsung
Maxtor, Western Digital
qwerty
22 Mb/s @ home, 1 Gb/s @ server
All of my systems still run fastest on XP 32-bit for the most part. Win7 is fun to play with, but I still prefer XP for raw speed, security, and functionality.
Thanks for the vote.
I think we could use a couple more stickies in this forum ;)
76~2.0
Onboard VIA VT2021
22" LCD Dell
Corsair HX650W
Logitech Wave
CM Sentinel
Dismal
Opera Next
Wow, nice Dave. I haven't ever seen this guide before until now. This should really do folks well and I'm sure it already has. +rep
self built
7600.20510 x86
P4 550 3.4 GHz HT running at 3.5 GHz
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
OCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHz
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
Thanks torrentg,
It does help, gets the basic info/questions answered, so we can get a resolution quicker.
76~2.0
Onboard VIA VT2021
22" LCD Dell
Corsair HX650W
Logitech Wave
CM Sentinel
Dismal
Opera Next
I have used this message with the links inserted & the response has been favorable !
Welcome to SevenForums,
Try some of our SevenForums reading material for a few minutes:
We are trying to help a lot of users and we will get back to you shortly.
Help us help you by providing more details of your system & problem.
on motherboard
6 pata Ide HD's & 2 Sata HD's
All Generic Full Towers
Fast Cable InterNet
Linked via TeamViewer !
I saw that today, looks good, Seems like most people are taking advantage of it once they realize it will help them get a solution quicker.
76~2.0
Onboard VIA VT2021
22" LCD Dell
Corsair HX650W
Logitech Wave
CM Sentinel
Dismal
Opera Next
Thank you for your information, It is useful to me.
windows XP 32bit
Great thread, glad to see it as a sticky!
You could (if you want) go to your own edit system specs page and copy the address and paste it into your post. Just as its like in my sig, The link was from my edit system specs, but when another member clicks on it, it takes them to there own "edit system specs". Or just right click and copy shortcut on my link in the sig and paste wherever. I have it there in my sig in hopes of new members (and old) that haven't filled them out yet to take the time out to do so as it definitely helps with answering most members questions.
Nice Work! :cool:
POS
OS3.5
celery
Good Question ...Unknown
memory never forgets
OB
OB
HUGE
168000000x105000000
full
OEM 65watt
N/A
OB
OB
mouse
1 Trillion MBps
Still An Awesome Forum!
Your welcome daisy2010, glad it was helpful.
Thanks OEM,
Good idea, it's definitely helpful to know the system specs, would be nice if everyone filled them out.
76~2.0
Onboard VIA VT2021
22" LCD Dell
Corsair HX650W
Logitech Wave
CM Sentinel
Dismal
Opera Next
