Radeon X1650 Pro (512MB) PCI-e (Help needed)
GhostRaider
11:27 AM
A couple days ago I finally decided to try out Windows 7. To my surprise if found myself liking the experience (I was one to downgrade back to XP from Vista).
So far I haven't run into any problems except my video card.
In the setup I am using I also have my computer hooked up to my Tv so I can watch the movies I download. Right now I am at a standstill because I can't clone my desktop onto my TV which would allow me to watch the movies.
The primary drivers for my monitor work perfectly. I have no complaints there. It is just getting that Catalyst Control Center to work (which it won't) so that I can select the "clone" option that is screwing me up. Other than that my experience with Windows Seven has been flawless.
So far I have tried using both the 32bit and 64bit versions of Windows 7.
With the 32bit installed everytime I tried to connect my second conneciton to the video card my primary monitor would go dark and my TV would take over as the primary monitor. None of the drivers out there that I tried (both the new catalyst drivers and the last updated drivers for X1650) would fix this.
I then switched over to the 64bit version of Windows 7 and got a little bit better results. This time when I would connect to my TV my main computer monitor would still stay my primary monitor and my TV would stay secondary. The problem is the only thing that shows up on my TV is the Windows desktop background and nothing else. No start menu no nothing will appear other than that background. As of right now that is where I am at.
With that said is there any fix out there for this problem at this time? If not can I expect a fix for this in the future or should I just start making plans to put a little money back here and there to buy another video card that can fall within my limited expendable budget.
Any help into this problem would be greatly appreciated as I would like to make the switch over to Windows 7 now rather then wait a couple months when I can afford another 60 to 100 bucks to buy another video card that can support HD.
Again any help would be greatly appreciated.
Home Build
Windows 7 Ultimate (32-bit)
DualCore Pentium D 940 Presler (64bit)
Biostar G31-M7 TE
4GB DDR2 800MHz PC 6400, 4GB via RamBoost
XFX Radeon HD 5770 (Juniper XT) 1GB: (ATI Catalyst 10.4)
Creative Audigy SE (SB0570) Sound Card PCI
22" Gateway FHD2102 Class 1080p HD Plus LCD Monitor
Gateway Monitor 1920x1080 and Toshiba 40RV525U Tv 1920x1080
(Primary) Seagate 500GB 7200RPM 32MB Buffer Serial ATA II
(Secondary) Maxtor 500GB 7200RPM 16MB Buffer IDE (Converted to Serial ATA)
LOGISYS PS550AC 550Watts ATX12V Power Supply
MidTower: Thermaltake M9 VI1000BWS
Zalman CNPS9700
Logitech LX7 Cordless Optical Mouse
Logitech Cordless Desktop EX 100
Additional cooloing: 2 Icages(intakes), 2 - 12cm side panel fans(intakes), 1 - Rear Panel 12cm fan(outtake)......
Computer is also connected to a Toshiba 40RV525U 40-Inch 1080p LCD HDTV so that I can watch movies off of my hard drive and dvd player.
GhostRaider, welcome to the forums.
Part of the problem is that ATI is not putting out any official Windows 7 drivers for that card, or any card prior to the HD2xxx series, due to lack of WDDM 1.1 support in the cards. If you haven't yet I would try the latest Vista driver for your card,
ATI Catalyst™ Legacy Display Driver
will probably have to install it in compatibility mode.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Thanks for the welcome Stormy.
Unfortunately I have tried those specific drivers on both the 32 and 64 bit systems. As well as the newest ones from the stickied post at the top of the forum. I get basically the same results with both with just a little better results on my 64bit system.
Can I ask what do you mean (and sorry for my ignorance...I am not that computer savy...just enough to get by) "install it in compatibility mode"? How do I do that. So far all I have done is download and install. Is this a different method of installation and if so how do I do it?
Home Build
Biostar G31-M7 TE
Zalman CNPS9700
Hi GhostRaider,
If I understand right, you now have succeeded in having both monitors showing picture,
but your remaining problem is that the second monitor only show an empty desktop?
Well that is the default dual screen layout. Under XP it was exactly the same.
You can drag screens from your first monitor to that desktop.
But if you want the TV to show the same as you have on the other monitor,
you need to select clone instead of dual screen.
Clone will give you identical views on the monitor and the TV.
good luck
Greetz
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
14" AOC CRT 16K color
800x600
300mb Quantum fireball
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
Hi GhostRaider,
Hello and you are correct.
You are correct again.
And now may I say HOLY CRAP!!!:D And thankyou for pointing this out. This basically solves my problem which also in a twist of irony is a problem I didn't actually have in the first place now that you have pointed it out LOL!!!
Do you know of any way of selecting the clone option (without using the control center)? That is the glitch. The CCC doesn't appear to work when click on it nor does it ever show up on the taskbar.
It (clone) is what I have always used hence my total ignorance of what my card has been defaulting to since I started using the 64bit system unbeknownest to me. That is the only problem that I am/was facing until you provided me with that bit of knowledge that fixed my problem.
If you have some insight to that it would be greatly apreciated and even if you don't a great big THANKYOU!!!! to you squonksc as you have solved my initial problem.
Home Build
Biostar G31-M7 TE
Zalman CNPS9700
Right click on the desktop and select "Screen Resolution". On the window that opens should be a line called "Multiple displays", just select duplicate from the dropdown menu.
P.S. FWIW ATI removed the whole clone/extended options from the CCC (at least in 7), as Windows 7 has the functionality built-in.
One more thing to check regarding CCC. Open Task Manager and see if both CCC.exe and MOM.exe are running. If not try the "Restart runtime" shortcut in the CCC folder in the Start menu, and see if that will get it going.
Also to install in compatibility mode right click on the driver file and select Properties, then click on the Compatibility tab and set it to Vista (I would go with the SP2 option); may also want to check off the "run as administrator" option as well if UAC is enabled.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
And with this you just solved my original problem as stated. Thankyou.
Opened the task manager and they were both running. Tried the "restart" and still got nothing. But this isn't really important anymore as you have shown me how to clone my desktop to my Tv.
Thanks for this bit of info.
Again thanks stormy13 and squonksc. You both have been godsends.:)
Home Build
Biostar G31-M7 TE
Zalman CNPS9700
Home Build
Biostar G31-M7 TE
Zalman CNPS9700
