Solved Realtek HD Audio EQ settings problem
Androi
10:18 PM
Hello. :)
i have a problem with Realtek Preset EQ
when i change the EQ settings .. it works perfectly while playing a song
but when i close the audioplayer and restart it again the EQ settings back to it's default
so.. how can i save this settings and make it work everytime i lunch a media palyer?
:confused:
Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
INTEL Corporation H61M-S2P
4.000 GB
NVIDIA GeForce GT 220
(1) High Definition Audio Device (2) Realtek High Definiti
WDC WD5000AAKX-083CA1 ATA Device
up up up
4.000 GB
After you make your EQ setup, there is a SAVE button to the right of the sliders.
Push that SAVE button, and then enter the name you want to save the EQ setup as. That setup will remain in effect until you change it.
You can save any number of EQ setups, and you will also be able to re-load them by name.
NOTE: You will lose all of your saved EQ setups whenever you upgrade Realtek audio drivers to a new version. That's because the so-called "upgrade" actually consists of two steps: (a) UNINSTALL current driver, and (b) INSTALL new driver.
And unfortunately that first UNINSTALL step deletes all of the Realtek Registry keys, which unfortunately deletes all the EQ setups since it is in the Registry that the SAVE process for an EQ setup gets stored. Too bad they don't put it in \ProgramData or \Users where it obviously belongs and could be preserved.
So be sure you write down how many +/- ticks you push each slider up or down for each EQ setup, since you're going to have to reproduce and save each one all over again whenever you do decide to upgrade your driver version.
Home-built, two systems (1) and (2)
i5-3350p 3.1Ghz/6MB-cache (1); E8400 3.0Ghz/6MB-cache (2)
ASUS P8Z77-V Pro (1); ASUS P5Q3 (2)
8GB PC3-12800 DDR3 (1); 4GB PC3-10600 DDR3 (2)
ATI HD7750 (1), (see TV cards); ATI R7 250 (2)
Realtek ALC892 HD Audio (1); Realtek ALC1200 HD Audio (2)
Eizo HD2441W LCD, Eizo S2433W (1); Eizo 24" S2433W (2)
1920x1200, 1920x1200 (1); 1920x1200 (2)
(1) 1TB SATA-II (7200RPM), 2x2TB SATA-III (7200RPM), 250GB SATA-III (10000RPM) for OS; 2x2TB external USB 3.0
(2) 320GB SATA-II (7200RPM), 750GB SATA-II (7200RPM), 150GB SATA-II (10000RPM) for OS; 2TB external USB 3.0
Nesteq ECS-6001 600W (1); Nesteq ECS-5001 500W (2)
Acousti-Case 360 (1) and (2)
Noctua NH-U12P SE2 for CPU, 2x120mm case fans (1) and (2)
IBM PS/2 (1) and (2)
Logitech MX Revolution wireless (1); Microsoft wired (2)
100mbps down / 10mbps up
Microsoft Security Essentials; Malwarebyte Anti-Malware Pro
Ceton InfiniTV 4-tuner cablecard-enabled TV card as well as Hauppauge HVR-2250 OTA/ATSC 2-tuner TV card in (1), running under Win7 WMC
It Worked thank you :)
4.000 GB
WOW! 10 weeks to solve that one. :sarc:
Hewlett packard/p6512uk
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
Hey! I have the same problem, with saved presets! I set it up, save it while listening to music. When I restart the Win Media Player, I get default sound, when I tweak a bit the EQ setup it goes back to the saved preset, but if I restart WMP it gets resetted again. I updated to latest version, I have no idea, it didn't use to do this, it started to happen after I bought a new headset (same as previous, just it was broken), I have no idea.
Agem
Windows 7 64bit
AMD Phenom II X4 3,2GHz
4GB GDDR3
AMD Radeon 6850
