Solved Realtek high definition audio max volume is about 50% than before,help
tadasjag
2:15 AM
hello. At some point I chose to reinstall Windows. I installed and updated all the drivers, etc and set the speakers up the same way as before. Only this time the audio was around 50% of the volume it was previously with volume up full. I reinstalled all audio drivers 5 times already, dont know what to do... i am running creative speakers 5.1. The drivers i have are : View image: fghfghfghfgh
I use green jack for front speakers , blue for rear speakers and pink for center/subwoofer. Please help, i want to get my full capacity sound!! (((
Windows 7 Ultimate x64I3-2100 - 3.1ghz4gbGeforce 640GT
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
Hi tadasjag and Welcome to Seven Forums,
Can you roll back the driver and see if it fixes the problem?
Windows 7 ProIntel Core i34 GBNvidia Geforce GT 630M
Windows 7 Pro
Intel Core i3
Avast Internet Security 2014
i rolled them back, now my audio manager is gone and i have only stereo speakers, need to download good manager to set jack for center, and rear speaker, cause i hear only stereo
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
Do you see in the screen shot you gave me there is a "Roll Back Driver" button over there click it (not in the picture) and follow the steps and it should roll that driver to an earlier version and it should work.
Windows 7 Pro
Intel Core i3
Yes i rolled them back, now im missing audio manager where i can setup 5.1. in playback devices through speakers, i can only pick stereo now
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
Yes because its an old version you can now update the driver to its newest version and if you get the volume error back then it must an error with the driver not your PC.
Windows 7 Pro
Intel Core i3
oky, then im going for the update and will post if it fixed :)
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
Maybee its a driver problem can you try it on your neighbor or friend's PC?
Windows 7 Pro
Intel Core i3
hm, i have a pc that i took for repairs, ill try the speakers on it. But IF the problem continues, is it possible to download some other drivers? Mother board: H61m-DS2
I can test the speaker only in a day or 2. Need parts for the other pc to make it working.
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
Yes of course you can but first just test it on another pc so we can make sure it is not your PC or OS that have the problem :).
Windows 7 Pro
Intel Core i3
Okey, so ill be back on this thread in about 2 days with the results :) thank you for your time and after few days, i will ask for some more of your time :))
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
Well that depends because you cant controll that sound coming from the .mp3 file.
Windows 7 Pro
Intel Core i3
In playback properties of the device what are the levels set at? Also what is the program your using to play back the music?
10 Pro x64Ryzen 9 3900X64GB(4x16GB) DDR4EVGA 1080ti FTW3
10 Pro x64
Ryzen 9 3900X
Asrock x370 Tachi
64GB(4x16GB) DDR4
EVGA 1080ti FTW3
ASUS Xonar Essence STX (V4 Bursons), ODAC rev B, NFB-11, O2
3xASUS PB278Q/R, Optoma HD142X
3x1440p, 1080p
512GB 850 EVO(OS, Programs)
4TB (Movies)
3TB (Downloads)
3TB (Programs)
1TB HDD (Games)
2x6TB R1 (videos)
AX760
Fractal Define R5
NH-D15S
Massdrop Ctrl with Box Navy's
G903, Alioth XXL Mat
MBAM, ESET
Canary 64 Bit
I also own a Thinkpad P50 Xeon 4K, X220T, X1C5
all 100%. I use aimp3 player and sometimes vlc media player for higher sound... :(
I3-2100 - 3.1ghz
gigabyte H61M-DS2
4gb
Geforce 640GT
