Recording issues with recorders (fraps hypercam etc) sound issues
MajorFoley
11:33 AM
Hey guys, ive lately been making lets play and walkthroughs on youtube and im having a couple of problems.
With my headset, in the background while recording thats like a static noise and i cant seem to make it go away, ive tried multiple recording programs like fraps and hypercam but its still there. Even when i lower my volume its still there. Im using an onboard soundcard and i really want to fix this issue. If anyone can provide help it would be apprectiated
windows 7 Ultimate Service pack 1 x64intel i5 2500k8gb RamSapphire AMD 6950 2gb
intel i5 2500k
Asus p8z68-v motherboard
8gb Ram
2x samsung hd103SJ
1x ST2000DL003-9VT166
Silverstone silver 850watt power supply (ST85F-P)
silverstone raven RV02-E
microsoft side winder x4
Razer death adder v2
apparently upto date
hi,
try to update your drivers
Well apparently their up to date when i go to device manager and go update drivers.
intel i5 2500k
8gb Ram
2x samsung hd103SJ
heres a video
Heres a small 10 second clip that i have with the static in the background for me anyway
intel i5 2500k
8gb Ram
2x samsung hd103SJ
specs
here are my specs
intel i5 2500k
8gb Ram
2x samsung hd103SJ
bump
bump anyone? i did post my specs and i apparently have latest realtek drivers, ironically if i use the mic mute option on my small control panel the static stops, yet theres no sound that can cause said static coming from anywhere
intel i5 2500k
8gb Ram
2x samsung hd103SJ
no one?
no one has any ideas that can help me out?
intel i5 2500k
8gb Ram
2x samsung hd103SJ
Can you post up your sound card info, I need to know the model of the Realtek device, I know it's Realtek high definition audio device but I need to know if it's alc888 or above, you can download this file from realteks taiwan website(slow connection I know) http://www.realtek.com.tw/downloads...=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Just to clarify, you said that your audio driver was up to date, but that's windows driver model version which Microsoft make for general compatability, they will not give you full functionality and management of your codecs
Windows 7 Ultimate x64 SP1Intel Q6600 @ 2.6Ghz4Gb DDR2 Corsair Dominator @ 800Mhz 5-5-5-15EVGA 560 GTX SC FTW 1GB
Evga NF78-CK-132-A 3-Way SLI
Realtek HD 7.1 Audio, Plantronics GameCom780 7.1 Headset
Dell S2409W
SanDisk SDSSDHII-120G-G25 120GB SSD
Samsung 7200RPM 750Gb SATA
Samsung 850 EVO 120GB SSD
Western Digital Green 1TB 7200RPM
Xigmatek 750W Quad sli quad core 80% eff
Antec 900 Gaming Case
Zalman CNPS9700-NT NVIDIA Tritium
Logitech generic keyboard, MS wireless keyboard
Razor Lachesis Banshee V2 Blue, 4000DPI, MS wireless mouse
152Mb Virgin Media Fibre Optic
Wireless Gaming Receiver for Windows, Wireless Xbox 360 Pad
alc
hi, thanks for replying, its ALC 892
intel i5 2500k
8gb Ram
2x samsung hd103SJ
Ok, click this link Realtek and select the second driver down from the top, then choose the server closest to you from the right, I'm assuming hong kong(HK) is closest to you (Austral-Asia), hopefully this will give you the tools to eradicate the elusive static
Dell S2409W
drivers?
so this is another driver? R2.69?
the tools that will help? what tools exactly? and how would i get rid of it using these tools
(its gonna take about 17 minutes to download atm)
intel i5 2500k
8gb Ram
2x samsung hd103SJ
when you plug your mic in, you'll get a realtek control panel come up, it'll ask you what device you've plugged in, when your mic is plugged in, you will get a mic options window, this will display the following options
now all you need to do is check the noise suppression option
Dell S2409W
I have that option on my current version but its greyed out, is that because of my hertz settings?
intel i5 2500k
8gb Ram
2x samsung hd103SJ
should be irrelevant, mine was greyed out but i clicked on it anyway and it enabled.
Dell S2409W
ok it stilll greyed out and clicking it did nothing, when i switched it from stuido 16 bits 192000 hertz to dvd quality 48000 hertz it become ungreyed, and i was able to tick it, im testing now to see if this stopped the problem
intel i5 2500k
8gb Ram
2x samsung hd103SJ
Oh my god Thank you so much it actually solved the problem. thanks, i guess part of the problem was also that the studio hertz options werent letting me click noise suppression, now i wont have static in my videos. Thanks!
intel i5 2500k
8gb Ram
2x samsung hd103SJ
You're welcome, If you want to post some of your youtube videos up here then by all means, you can do.
Dell S2409W
i guess well my channel is here, i started commentating on my videos with my age of mythology ones (Starting from level 3 onwards)
MajorFoley1 - YouTube
intel i5 2500k
8gb Ram
2x samsung hd103SJ
fixed static but maybe another problem?
hey guys thanks again for solving my static problem but i think i may have run into another, my voice on the recording sounds... i dunno different a bit? like it doesnt sound as clear. was this because i lowered the hertz to enable noise suppression?
intel i5 2500k
8gb Ram
2x samsung hd103SJ
