Registry Problem - No Sound & Memory Error Msg. System Restore crashes
I think the dash before rec might not be a hyphen. I'm going to try this again without copy/pasting. That would explain why it worked with lines 1 and 3 because I manually typed it then. But copied pasted for lines 2 and 4.
If that does not work, have you tried the commands in Safe Mode since less software is loaded there?
HP Pavilion e9110t
Windows 7 Home Premium 64 Bit
Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Pegatron IPIEL-LA3
6.00 GB Hundai HMT125U6BFR8C-H9
ATI Radeon HD 4850
Realtek High Definition Audio/ATI High Definition Audio
Acer AL2216W
Hitachi HDP725050GLA360 ATA Device 500 GB
Unknown/installed by HP
HP generic case
Intel Stock Cooling
HP Keyboard
HP Mouse
Download: 19.15 Mbps Upload: 1.67 Mbps
Network Adapter Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
Network Adapter 802.11n Wireless PCI Express Card LAN Adapter
OK I was able to run lines 2 and 4, in fact I did it from the Repair Disc's command prompt to ensure there wouldn't be any conflicts. But still no improvement. Was that supposed to fix it?
HP Pavilion dv4 Notebook PC
Windows 7 Home Premium SP1 64bit
Intel Core i3
M 330
NONE
ON BOARD
LCD
LOCAL DISK C) 76.6 GB free of 278 GB
RECOVERY D) 3.05 GB free of 18.9 GB
HP_TOOLS E) 64.2 MB free of 99.3 MB
Thanks for the tip. I'll try subinacl in safe mode.
Intel Core i3
M 330
NONE
ON BOARD
LCD
OK I ran both of these now in safe mode and for some reason this has no effect on fixing my registry or software or whatever went wrong. I have told you everything, I Swear I'm not keeping any secrets from you. I don't know why this isn't solving the problems (like sound not working) except that maybe I just don't have permission to edit the permission on these keys. :(
Should I be adding all users I wonder to the keys I wonder? So far I've only added administrators and system.
It still doesn't add up why I can't import my backup of the registry or do a system restore. Should I just start uninstalling programs and see if that fixes it?
subinacl still said failed when trying to update about 1/4 of the registry key permissions that I saw.
Intel Core i3
M 330
NONE
ON BOARD
LCD
This is impossible for recovery environment!! You did change the regkeys of recovery environment's mini windows itself. Doesn't matter it's in ramdisk so lost after reboot
ACER ASPIRE 5742G
Acer Aspire 5742G
4,00 GB
WDC WD5000BEVT-22ZAT0
not subinacl but setacl!!
So these 2 lines fail?
SetACL.exe -on "hkcr" -ot reg –rec yes -actn ace -ace "n:administrators;p:full"
SetACL.exe -on "hkcr" -ot reg –rec yes -actn ace -ace "n:system;p:full"
ACER ASPIRE 5742G
Acer Aspire 5742G
4,00 GB
start regedit
rightclick on HKEY_CLASSES_ROOT then select security then aadvanced.
who's the owner? What are the permissions?
post screenshots
ACER ASPIRE 5742G
Acer Aspire 5742G
4,00 GB
What happens if you create another user? Are you able to then get sound?
HP Pavilion e9110t
Pegatron IPIEL-LA3
ATI Radeon HD 4850
Acer AL2216W
HP generic case
Intel Stock Cooling
HP Keyboard
HP Mouse
Intel Core i3
M 330
NONE
ON BOARD
LCD
I used those two lines of setacl and they did not fail or report errors but like I said the hkcr lines I ran from command line. I had no idea that they wouldn't have any effect from there. I assumed that was the best place to do it so that the registry would not be in use. I'll try all four lines again in safe mode.
I used subinacl and got message that 1/4 of key permission updates failed in safe mode in the directions you gave me here: Tech XE » How to Reset Windows Registry Permissions
I'm now also getting a message that my recycle bin on drive C: is corrupt.
Intel Core i3
M 330
NONE
ON BOARD
LCD
OK I finished running those 4 lines again in safe mode. Took all night to complete because of the verbose output, but it said it completed successfully. Then I restarted windows normally. No sound still. What should I do next?
It seems that what I did last night just brought back the problem I was having before with Windows Explorer and other things not working.
I still have a backup of the registry from before all of this started. I've tried importing it but it never works. Is there some way to do that?
Intel Core i3
M 330
NONE
ON BOARD
LCD
At this point, with all the registry workarounds and the problems they have apparently caused, plus the fact that you are unable to get Windows to restore using a restore point, I would suggest doing a http://www.sevenforums.com/tutorials/3413-repair-install.html to fix the registry and re-install hardware drivers into the registry.
HP Pavilion e9110t
Pegatron IPIEL-LA3
ATI Radeon HD 4850
Acer AL2216W
HP generic case
Intel Stock Cooling
HP Keyboard
HP Mouse
I can't do a repair install can I? Don't I need a Windows 7 disc for that? I didn't get one when I bought my computer. Should I have?
Intel Core i3
M 330
NONE
ON BOARD
LCD
I used to be able to press F8 and then go to Repair My Computer, and I had Restore Factory Settings, and Minimized Image Recovery and other recovery options there, but now just since yesterday when I hit F8 and go to Repair My Computer, it just starts windows normally. I can't even go to Command Prompt or System Restore or anything like that. The only changes that I've made to the system were the setacl changes exactly as instructed here.
Intel Core i3
M 330
NONE
ON BOARD
LCD
HP Pavilion e9110t
Pegatron IPIEL-LA3
ATI Radeon HD 4850
Acer AL2216W
HP generic case
Intel Stock Cooling
HP Keyboard
HP Mouse
Thanks for the link to the ISO link. I didn't know I could download Windows 7 DVD from online. That's good to know. Is that a trustworthy source though? Do you think a repair install would be enough?
Intel Core i3
M 330
NONE
ON BOARD
LCD
Will a repair install know what drivers I need? Or does it not reinstall any drivers? I assume I could just download the drivers and reinstall them from HP if I have to.
Does it repair the registry? Even when it's obviously fubar-ed like it is now.
Intel Core i3
M 330
NONE
ON BOARD
LCD
It is a trusted link. It is an official link for the software and I have used it myself for my systems to do repair installs.
It will repair the system portions of the registry, and it will re-install hardware and drivers, so it should fix your problem. If not, the only option left is a clean install, but I am hoping we will not have to go to that step.
HP Pavilion e9110t
Pegatron IPIEL-LA3
ATI Radeon HD 4850
Acer AL2216W
HP generic case
Intel Stock Cooling
HP Keyboard
HP Mouse
If System Restore won't work from System Recovery Options on the DVD or Repair CD, and SFC finds no bad System files to fix, then your last resort is a Repair Install.
Back up your files and make your HP Recovery Disks first.
If this fails you can Factory Recover, trying first using this method: HP Recover Windows 7 Operating System Using HP Recovery - HP Customer Care (United States - English) then if that fails by booting the Recovery Disks.
Or for a leaner install you can clean reinstall following these steps to get a perfect clean reinstall of factory OEM: Reinstalling Windows 7
Thanks. I burned a DVD with that image and it boots.
My computer is too full of stuff to do a backup of everything. I just don't have that kind of space on anything external that I have. That's not really necessary though for a repair install though is it.
Can you walk me through doing a repair install? I've already booted from the disc, do I just click Install? Do I need to make a note of anything before it starts?
What about my drivers? It came with everything already installed. Will it automatically figure out what it needs to install?
Intel Core i3
M 330
NONE
ON BOARD
LCD
