Solved Right Click Menu Display Problem
hasanhizli
9:08 PM
Hi all,
I have a strange problem. When I right click on a file (.exe, .dll, .jpeg, ...) I end up with a screen as in the attachment. (It should be like in http://images.maketecheasier.com/2009/12/win7-right-click-copy-move-to.gif )
However, there is no problem when I right click on desktop, it is as it should be (no blue band). I have a desktop PC and a laptop and both has the same problem. I tried system restore but no solutions:( What can be the reason? A virus or a malware (despite Avira and A-squared installed)?
ASUS
Win7 Ultimate
T9600
4GB
Nvidea 240M
Is it always the same entry that shows in blue? If yes, what is it (hard to read the entries in your language). Anyhow, the desktop right click menu is different to other right click menus.
Would help if you could translate it to English...
W7 RTM Ultimate x64
Intel Q8400 @ 2.66GHZ
Gigabyte GA-EG45M-UD2H
4GB DDR2-800
Integrated 8 Channel
AOC 23.6 Inch Widescreen LCD
Seagate 500GB Internal
Western Digital 1TB Internal
Hitachi 1TB External
Apevia Java Power 500W
Cooler Master HAF 922 Black
Stock Intel CPU Fan
1.5MB
All the entries are in blue (winrar commands, copy, cut, etc.) I will format win7 on my desktop PC but dont want to do the same for my laptop. I want to learn the magic behind this. If you want english version of the menu, it is as follows:
Open
Print
Create PDF and Bitmaps using PDF creator
open with
Share with
Scan selected files with avira
add to archive
and regular winrar stuff
jetaudio
load previous versions
send
cut
copy
create shortcut
delete
rename
properties
ASUS
Win7 Ultimate
T9600
4GB
Nvidea 240M
Problem Solved:
The reason is a beta version of a-squared ant malware installed. After uninstall it, the problem disappeared.
ASUS
Win7 Ultimate
T9600
4GB
Nvidea 240M
