Have been trying to install a high gain USB wireless long range wireless network adapter to my laptop. Initially tried a Alfa AWUS036h, software installed ok, but it never detected any networks and in Network Connections it was showing disabled. Any attempt to enable started well, showed enabling but the icon stayed at disabled. I presumed it was a problem with the device so returned it on Amazon and purchased a RT73 USB Wireless LAN Card but it has the same issue. Tried the device on a XP laptop and installed and operated brilliantly. Both devices stated on the packaging that they were Windows 7 compatible. Have checked that I have the latest driver from the manufacturer. Any suggestions???
- Dell
- Windows 7 Home Premium 64bit
